245/35/19 tires on stock 19" Rays Wheels?
Old May 24, 2007 | 05:24 PM
tonirev's Avatar
I need tire replacements for the stock 19" g35 coupe dual spoke rays wheels...
Some local retailer quoted me a great price for 245/35/19 tires, for 4. He said if I go 245/35/19 all around it should be fine.
However, the stock ones are 225/40/19 FRONTS, and 245/40/19 REARS.
Do you guys know if it will be alright? He also said I could go 245/35/19 rears and 235/35/19 fronts if i wanted to. Unfortunately he doesn't have the stock sizes.
Should i just go 245/35/19 all around? Will that screw up my speedo or anything?
Help appreciated, thanks
Old May 24, 2007 | 05:26 PM
redlude97's Avatar
don't put 245/35/19 all around and especially not on the rear. Go stock sizes, or 245/35/19 front 255/40/19 rear, your speedo WILL be screwed up with a 245/35/19 in the rear and your VDC may also not like it
Old May 24, 2007 | 05:55 PM
tonirev's Avatar
thanks...how about
235/35/19 in the front and 245/35/19 in the rears as a combination??
Old May 24, 2007 | 05:57 PM
redlude97's Avatar
Originally Posted by tonirev
thanks...how about
don't put a 245/35/19 on the rear AT ALL!
Old May 24, 2007 | 06:00 PM
tonirev's Avatar
I thought the stock ones were very very similar, 245/40/19... a size of 245/35/19 would screw it up?
Old May 24, 2007 | 06:06 PM
redlude97's Avatar
245/35/19 is almost an inch shorter than stock and will throw off your speedometer by 3.6%, why don't you just get the correct size?
Old May 24, 2007 | 06:10 PM
ttrank's Avatar
Grocery getter
You can do it, just be aware that your speedo will be off.
Old May 24, 2007 | 06:17 PM
Jeff92se's Avatar
Red Card Crew
I think you should look up what the RIGHT tire dia are for diff sizes. Use one of the many tire calcs on the net. Miata.net has one.
I think you should concentrate on putting the right sized tires on VS whatever the salesman you are working with has in stock or just happens to be able to get.
tonirev's Avatar
thanks guys..
yeah i'm saving about $600 if i go w/ the sizes i mentioned as opposed to getting the perfect stock sizes
but i might just pay the extra and not have to worry about it
Old May 24, 2007 | 06:18 PM
redlude97's Avatar
yes, and you'll have less pothole protection, and it'll just look goofy in general
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Popes
Jul 29, 2015 05:07 PM
realtalk21
Jul 20, 2015 09:07 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
