Will mixing these tires BAD ?BFGoodRich (F),Toyo (R)
Old May 26, 2007 | 07:56 PM
fhumphrey04's Avatar
I dunno, Im running some cheap off brand tires on the front and Nitto NT555 in back (hate them, but they came with the wheels) and it hasnt affected my car at all. I'm sure if you get going really high speeds it wont be good or if you have different tires on the back or front, but thats not your case anyways.
PS- of course tire rack will tell you that it is terrible because they are going to try and sell you a new set. Just be careful!
Old May 27, 2007 | 02:12 AM
cutiewolf's Avatar
icic...owellz i guess ill just stick with bf-goodrich better than later on problem comes...so should i just replace one or both pair in the rear? the pin hole is right between the middle of the sidewall and the theards is leaking air ...where can i take it to to get it repair? i took it to 1 tire shop 2 body shops by expert...they all said it has the be replace...but i dont know..
Old May 27, 2007 | 01:09 PM
g35rcr's Avatar
sidewall's cant be repaired...you can put toyos in the back and keep the bf goodrich in the front with no problems...
vitamin.v
Nov 7, 2019 06:10 PM
ScraggleRock
Aug 11, 2015 10:16 PM
Phenomenon9
Aug 9, 2015 01:34 AM
joedaddy1
Jul 28, 2015 02:58 PM
