Chico or any other of the wheel Gods out there..
Search results came out good...I know they will fit....but just need to hear from a couple board members before I make the purchase. This is going on a 2003 G35 Sedan dropped onTein Htechs.
The Wheels:
20x8.5 with a 36+ offset on 245-40 rubber all the way around.
My question is...how will this look? ride? will I rub? etc...i've been waiting on 20's and this thread will either make it or break it...Thanks in advance!!!
The Wheels:
I cannot answer as to whether or not you'll fit/rub, but I can add this.....Your O.D. will be 27.7 inches....stock O.D. is 26.3 inches. You'll be over by 5.3%. Rule of thumb is you should stay within +/- 2 to 3% from OEM. Your speedo will be off by a lot. I run 245/40/19's (O.D. = 26.7 inches) and my speedo is off by about 2-3 MPH. I'm pretty sure with 20's, you'd want 35 series instead of 40.
Jim
Jim
Jim
Jim
Yes on 20's 245/35's are perfect. Very close to the oem diameter.
