Advice on what to do about my tires
Old Jun 12, 2007 | 11:20 PM
avs007's Avatar
Question Advice on what to do about my tires
So my rear Pilot Sport A/S were worn down to the wear-bars.. (At least the center band was)... So I got new tires for the rear. I bought Bridgestone Potenza RE960 A/S in 275/40-18 to replace the same sized Pilots.
I just got 4 of them for my wife's TL, and she loves them. Claims that the performance is much improved over stock....
My story is quite the opposite. The Michelin Pilot Sport A/S I have on my fronts (245/40-18) still have TONS of tread left.
Anyways, today was the first time I was able to drive the car since getting them installed last weekend. So I was getting off an exit, that had a sweeping exit curve... I don't think I was even going that fast, and it felt like the back end kept stepping out... I was like, "WTF?". I kept going, then I saw the VDC blinking....
Hmmm... When I got to Home Depot, I checked my tire pressure, and noticed the Potenzas were up to 38psi... So I lowered them back to 35.5psi, like I always keep my tires.
On my way back home, I took another freeway exit, that I ALWAYS took at 60mph, but the car didn't feel right, so I only took it at 50.
Then when I got to the banked curve near my house, I took it at 40. It made the turn, but as soon as I completed it, VDC blinked, and I heard a grinding noise from my front left. (I'm guessing it was braking the front-left).
So anyways, I'm scared to drive my car like this, and I need to do something...
Do you think the Potenza's suck compared to my Pilot Sport A/S, or do you think that the VDC is flipping out because I have Potenzas on the rear and Pilot Sports on the fronts?
With that being the case... Should I return the Potenzas and install Pilot Sport A/S, or should I replace my front Pilot Sports with Potenzas?
I was going by Tire Rack survey, which had the 960AS ahead of the Pilots, so I thought they should handle better. I also liked the 40,000 mile warranty, since the pilot sport A/S on my rears only lasted 20k miles.
I have no idea what I should do.... Help
Old Jun 12, 2007 | 11:21 PM
Alan's Avatar
35 psi warm is a bit low isnt it?
Old Jun 12, 2007 | 11:30 PM
avs007's Avatar
I was just being desparate wondering where my traction went... I usually keep my tires at 35psi cold.
I just went to tire rack, and compared the Pilot Sport A/S to the Potenza RE960AS.
The Pilot Sport A/S I had before, had an overal diamter of 26.6" or 777 revs per mile... The potenzas have an overal diameter of 26.7" or 780 revs per mile... Is that enough to screw up the VDC?
Old Jun 12, 2007 | 11:36 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
It's because you have the Michelins on the front, Bridgestone's dont play nice when you mix them with other brands, i have first hand knowledge of this as i work for Bridgestone and have tested it on my own car. I had pilots up front as well and switched to The 960's, the slip light went crazy even getting on an on-ramp at 40 i used to take at 70. So i figured it was the 960's, changed to the 750's and the same thing happened. The 960's are a great tire if you're running it all around, i was a bit weary the first time i was going on a canyon run with them, but they never let go of the road once, i was quite happy and surprised.
-GP-
Old Jun 12, 2007 | 11:42 PM
gary c's Avatar
Diffrent shoes...........?
Before you run out and buy new tires put 37 lbs in your tires "Cold!" See how
they react, if there still scarey spend the money for Michelins Pilot Sports.
I'm supprised the Tire Rack chose Bridgestones over Michelins, that's just not
bright!
Old Jun 12, 2007 | 11:49 PM
bright!
they have them over the Michelins for a reason... they're a better tire for less money. You woulndt know becuase all you buy is Michelin, i can say i've driven on both and they are both great tires, but the Bridgestone's win because of the price difference.
-GP-
Old Jun 13, 2007 | 12:27 AM
avs007's Avatar
So I'll probably bite the bullet and buy two more Potenzas over the weekend, and see if I can sell my Pilot Sport All/Season...
How much do you think is reasonable? They have 20,000 miles on em', but they still look practically brand new:
Old Jun 13, 2007 | 12:28 AM
you could probably get $100/tire on ebay for those, they look like they're in great shape on the outside edge.
-GP-
Old Jun 13, 2007 | 12:31 AM
ttrank's Avatar
Grocery getter
Those look awesome for that kind of mileage. I have not seen 20k on a set of tires in years.
Jussumman
Dec 22, 2015 10:23 AM
miata007
Aug 17, 2015 04:36 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
nascarbuff17
Jul 16, 2015 10:23 AM
