Oem lug nuts and aftermarket wheels
Aug 12, 2007 | 07:53 PM
Will oem lug nuts work with Work VS-XX or do you have to buy tuner lugs?
Reply 0
Aug 12, 2007 | 08:02 PM
tuner lugs
Reply 0
Aug 12, 2007 | 09:37 PM
What is the reason?
Reply 0
Aug 12, 2007 | 09:47 PM
tuner lugs are longer.
Reply 0
Aug 12, 2007 | 09:51 PM
Quote: Will oem lug nuts work with Work VS-XX or do you have to buy tuner lugs?
oem lugs WILL work. i know from experience.
Reply 0
well...i can't speak for the works but the oem lug nuts worked for my volks...but then i got sick of looking at those round bubbly looking lug nuts and bought some black rays lug nuts. just make sure they're 1.25mm.
Reply 0
Aug 13, 2007 | 02:51 AM
depends on your offset. I had to get open ended tuner lugs (Work lugs) cuz i ran a 5mm spacer with longer bolts on a 19 x 8.5 +42 offset wheels.
Reply 0
Aug 13, 2007 | 03:09 AM
dont cheap out now........get some sick lugs for the works
Reply 0
Aug 13, 2007 | 11:28 AM
Quote: dont cheap out now........get some sick lugs for the works
Ha no doubt, after dropping 2300 it doesn't make sense to go lame on the lugs. I wanted to use the oem wheel lock though, might look a little odd but rather have a little bit of security.
By the way truplay8, you're not dropped right? I'm thinking of not dropping because I have a front lip and a angled driveway unfortunately that will be a bitch to go up lowered.
Reply 0
Aug 23, 2007 | 01:14 PM
use tuner lugs for aftermarket wheels
because oem lugs and wheels have curved contact area where the lugs meet the wheels, after market wheels have flat contact area, therefore you would want to use tuner lugs because tuner lugs also have a flat contact area
oem lugs would probably hold the wheels in place, but would you risk damaging the wheels and your safety?
as far as security goes, mcgard do sells tuner style wheel locks, mcgard is the company that makes OEM wheel locks...well at least i know they makes OEM Honda locks...not sure who makes infiniti's locks,
Reply 0
Aug 23, 2007 | 01:22 PM
completely wrong....
this isn't a honda
Reply 0
Aug 23, 2007 | 01:41 PM
Quote: completely wrong....
this isn't a honda
do infiniti have tapered lug nuts/wheels? if i does i didnt know
Reply 0
Aug 23, 2007 | 01:50 PM
rays lug nuts aren't flat
Reply 0
Aug 23, 2007 | 01:52 PM
honda is the only company to use acorn style lug nuts
Reply 0
