Have had these on my BS sedan for less than a month with less than 500 miles. See classifieds "Parts/ Accessories" for details.
Thanks
Thanks
I have those rims. I didn't buy them because I thought they were the best looking rims I could buy, I bought them because no other rim can be had anywhere near their price point and have 19lbs in weight or less. I was looking at paying double to keep the same weight and sedan workable offsets (a absolute requirement for me) and have the look's I really wanted. I paid $250 per rim, which www.walentire.com is still selling them for, great price for a 19 pound 18" rim. In the end I decided that money saved could be spent better else where on the car. I'm running 245/40 (slightly shorter I know) and I plan on installing 255/40-18 when the current Kumho Mx's were out. On thing about the hyperblack, while the source of why I'm not totally happy about their looks (I'd be a lot happier if they were brilliant silver) they hide brake dust really REALLY well. And they are not that bad to clean, well I wash my car, then I wash my rims [img]/w3timages/icons/wink.gif[/img]
My car is lowered 1" on the 350Z suspension
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Edmund Burke
G35 6mt
They are tops in my book!!
Frank
CM Motorsports
Irvine, Ca 949 453 1199
2003 G35 5AT Sedan
K&N Typhoon
GReddy Evo Cat back
Tein Flex coilovers
Tein EDFC
Brembo
Nismo LSD
GReddy Twin Turbo's on Monday
Frank
CM Motorsports
2003 G35 5AT Sedan
K&N Typhoon
GReddy Evo Cat back
Tein Flex coilovers
Tein EDFC
Brembo
Nismo LSD
I just PM'd you over at Freshalloy. I think you should look into having them chromed. It might not cost that much and will give you the look you're looking for without taking the big hit by selling them.
Good luck, whatever you decide.
can i fit brembos in these? on my sedan of course.
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
G35S 6MT
Technosquare ECU
6-wire ground kit
Frank (g35Spot) has aftermarket brembos on his sedan and is running an 18x8 configuration of the same wheel on his fronts. From the pics, the size of his brembo calipers look bigger than the factory brembos and so I don't see why the factory brembos wouldn't fit. I would still independently confirm though.
Below is a link to Frank's car in the rides section
https://g35driver.com/rides/detailride.php?vehId=182
Frank hope you don't mind me using your ride as an example. BTW, what offset are you running in the front?
Franks offset's are way different than the RPM2's your selling.
He's running 35mm front 8"wide and 38mm rear 9"wide. Your rims, like mine are 45mm 8"wide, front and rear.
Edmund Burke
G35 6mt
Edmund Burke
G35 6mt
Thanks for the clarification. Thats why I asked and recommended independent verification, as I wasn't sure what his offsets were.
