tein coilovers??? should i?
Re: tein coilovers??? should i?
Damn near the best thing I have ever done to me G Sedan
Frank
CM Motorsports
Irvine, Ca 949 453 1199
2003 G35 5AT Sedan
K&N Typhoon
GReddy Evo Cat back
Tein Flex coilovers
Tein EDFC
Brembo
Nismo LSD
GReddy Twin Turbo's on Monday
Frank
CM Motorsports
2003 G35 5AT Sedan
K&N Typhoon
GReddy Evo Cat back
Tein Flex coilovers
Tein EDFC
Brembo
Nismo LSD
You probably won't feel the different if you spent money on intake or exhaust!! But, I bet you can feel the performance gain from it!!
03 DG 5AT Coupe
Clear bra/ Tint/ Z tube + stillen Airbox/ PIAA wedge
RS-R Exhaust
Eibach Sway Bar
03 DG 5AT Coupe
RS-R Exhaust
Eibach Sway Bar
Errrrrr which one's they make 3 different ones?
What do you want out of them, performance, comfort, looks?
Here are some specs, spring rates to OEM and front to rear balance to OEM.
Tein Basic Coilovers
350Z/G35 Coupe & Sedan
F/R spring rates Linear springs
504/504
Front to rear spring rate balance change VS OEM on
350Z/G35 Coupe
+45% stiffer front and +20% rear (25% transfer to front)
G35 Sedan w/sport +41% front +24% rear (17% transfer to front)
If 448lbs springs are run in front balance VS OEM
changes to:
350Z/G35 Coupe +29% front +20% rear (9% transfer to front)
G35 sedan w/sport +25% front +24% (1% transfer to front)
Tein CS coilovers
392/392
+14% front -5% rear (19% transfer to front)
G35 sedan w/sport +11% front -4% rear(15% transfer to front)
If 448lbs springs are run in the rear, front to rear balance
to OEM changes to:
350Z/G35 Coupe +14 front +7% rear (7% transfer to front)
Sedan w/sport +11% front +10% rear (1% transfer to front)
Tein Flex coilovers
672*/672*
*original kits were 560/560, most product reviews are based
on the 560/560 rates, buyer beware if your using these
review's to make a purchase decision.
350Z/G35 Coupe +94% front +60% rear (34% transfer to front)
G35 Sedan w/sport +88% front +65% (23% transfer to front)
If 560lbs springs are run in the front, front to rear (which is the front rates used by Jic coilovers on the 350Z application)
balance VS OEM changes to:
350Z/G35Coupe +65% front +60% rear (transfers 5% to front)
G35 sedan w/sport +60% front +65% rear (transfers 5% to rear)
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
504/504
350Z/G35 Coupe
changes to:
Tein CS coilovers
392/392
to OEM changes to:
Tein Flex coilovers
672*/672*
Edmund Burke
G35 6mt
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
