Spend $300 for wheel spacer for OEM 19 Rim + suspension
Old Sep 8, 2007 | 09:59 PM
kenempireex's Avatar
Should i set up Project kics spacer for my stock 19in rims and stock height? It will make the wheel gap look lower and flush. Or should I spend the money on something else?
Thanks for any input
Old Sep 9, 2007 | 12:52 AM
g35sedan5at's Avatar
300 dollars???? i think u can get H&R spacers for cheaper than that.
Old Sep 9, 2007 | 02:12 AM
I heard Project kic is the best
Old Sep 9, 2007 | 02:25 AM
UnluckyCharms's Avatar
I heard you were retarded. Go drive your car and don't worry about offsets and spacers unless you're going aftermarket rims. Use the money for gas or twinkies...
Old Sep 9, 2007 | 03:06 AM
almost sounds like i am using your money
Old Sep 9, 2007 | 04:40 AM
in2win's Avatar
Save your money, complete waste
Old Sep 9, 2007 | 05:08 AM
redlude97's Avatar
Greatly improves the look of the OEM 19's, but provides no performance benefit.
Old Sep 9, 2007 | 11:38 AM
ISMSOLUTIONS's Avatar
I've seen several cars with factory 19's and spacers - makes it look MUCH better. If your not going to buy wheels at all in the future...do it...you will love the new look you'll get. Everyone will think you have new wheels, or special versions/wider...
Old Sep 9, 2007 | 03:53 PM
gbabbitt's Avatar
What size spacers should be used for this? I have the 19 oem's and don't plan to change them. Also, I've heard it's best to replace the oem bolts with longer bolts, is this the best method?
Old Sep 9, 2007 | 05:27 PM
redlude97's Avatar
15/20 seems to be the most common setup. Personally I would go 25mm all around and roll your rear fenders, but thats just me
Old Sep 10, 2007 | 11:44 AM
bulldog25's Avatar
If i go 15mm all around with 235/35/19 fr & 255/40/19 r will i rub without rolling my fenders? I am not lowered, and prob wont since I have a pretty steep driveway.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
