19" Dr
Old Sep 26, 2007 | 03:52 PM
Jtrain's Avatar
19" Dr
Anyone put DR's on their 19" volks-- I'm starting to get into the track / 1/4 mile thing so I'm looking for grip.
Where do I get 19" DR... do they exsist lol?
Old Sep 26, 2007 | 03:54 PM
Jeff92se's Avatar
Red Card Crew
I don't think you want a 19" drag radial. Side wall would be too thin unless you run some ginormous dia.
Run some 17" wheels and put DRs on that.
Old Sep 26, 2007 | 04:24 PM
Jtrain's Avatar
I don't want to change rims =\
Old Sep 26, 2007 | 04:25 PM
redlude97's Avatar
so you are going to drive with DR's all the time?
Old Sep 26, 2007 | 04:26 PM
Jeff92se's Avatar
Red Card Crew
No one cares how your car looks at the track. You have to change wheels at some point. You won't want to run DRs all the time (even if they are dot legal)
Old Sep 26, 2007 | 06:21 PM
Jtrain's Avatar
I was thinking about it-- its just my weekend car. I don't know much about this tho.
Old Sep 26, 2007 | 06:24 PM
redlude97's Avatar
Just don't expect your tires to last more than a couple thousand miles at best
Old Sep 26, 2007 | 06:25 PM
redlude97's Avatar
drag radials also have pretty soft sidewalls, so your car will pretty much become only a drag strip car, handlng is going to be horrible
Old Sep 26, 2007 | 09:17 PM
Jtrain's Avatar
I was just going to put them on the back-- I only get 5-10k miles right now for a set.
I jsut dont get traction in first lol =\
Old Sep 26, 2007 | 09:26 PM
redlude97's Avatar
If thats all you get now, expect less than 1000 mi out of a set of DR's then
Old Sep 27, 2007 | 01:35 AM
Wishin's Avatar
I got 12-14k miles out of my kdw2's just tell apex you want the same tires I had before. Their the gripest street tire you can get, they hooked up pretty good for me and I was pushing a tee bit more power than you.
Old Sep 27, 2007 | 02:21 PM
Jtrain's Avatar
Haha, we gotta meet up sometime-- I pushing up my boost this weekend to 7psi... I've seen your car on the lift the past... weeks lol
If YOU got 14k miles on a set of tires, I'm buying them lol.
Old Sep 27, 2007 | 02:22 PM
jist26's Avatar
if you're looking foer a good 1/4 mile time your best is to go 17's jmo
Old Sep 27, 2007 | 02:25 PM
Jeff92se's Avatar
Red Card Crew
They aren't exactly DRs though.
Something like this is what I think he's looking for:
But also note what they say about running them all the time (aside from the non-existant treadwear rating)
The Drag Radial's popularity has resulted in some questions about the tire's high-speed capabilities because, unlike other Ultra High Performance street radials, its speed capability is not indicated on the sidewall by a speed symbol in its size or service description. While the g-Force T/A Drag Radial has many of the internal construction features usually found in high speed radial tires, the feature that prevents it from being speed rated in the "normal" ways is its unique high-hysteresis tread compound. This compound has extreme energy-absorption characteristics that help the Drag Radial readily conform to the track surface to help launch the car and take it to victory... an eighth- or quarter-mile at a time. This same tread compound, when subjected to continuous operation at high speeds, could possibly overheat and blister like super-sticky "qualifying tires" that have been used in professional oval track or road racing competition. Thus, even if the g-Force T/A Drag Radial is available in a vehicle's ideal size for use in activities other than drag racing, it should not be used in competition where the car and tire will be exposed to extreme cornering loads or sustained high speeds.
It is also important to remember that the g-Force T/A Drag Radial operates most efficiently on the strip at cold inflation pressures of between 15psi and 20psi (in no case should below 12psi be used). And after the racing is done for the day, it is essential that the g-Force T/A Drag Radial be reinflated to normal highway operating pressures before carrying the driver and trophy back home. Running any tire at relatively low inflation pressure for a given load reduces the tire's speed capability by causing it to stretch more and operate at a high deflection (more radial bulge). The Drag Radial is built to withstand brief "bursts" of high speed while inflated at low pressure (such as would be experienced on a quick car in the quarter-mile), but no tire can be expected to survive for a long time at high speed while operating at high deflection.
Old Sep 27, 2007 | 02:46 PM
Jtrain's Avatar
they dont make 19" DRs
I cant find ANY to even THINK about this
I'm not gettin different rims..
Yeah After reading that I guess it wouldn't work-- that's to bad.
