Tire Pressure Problem
Old Oct 20, 2007 | 04:24 PM
culi's Avatar
I bought my last set of tires last year and one wheel start to leak pressure slowly. So every two to three weeks I have to bring the pressure back up. The OEM set didn't have this problem. I thought it might be a bad tire and I don't mind checking my tire pressure. Anyway, I just bought a new set and that same freaking wheel is loosing pressure again. I think the TMPS is corroded and slowly leaking. Anybody comments from you guy? Could it be the wheel itself?
Also, where can I buy the TMPS?
Old Oct 20, 2007 | 05:20 PM
Silver350GT's Avatar
maybe the rim is bent? Did they put in new valve stems when they put on your new tires?
Old Oct 20, 2007 | 09:01 PM
DrrSeuss's Avatar
it's most likely the valve.
Old Oct 23, 2007 | 02:34 PM
culi's Avatar
I'm not sure if the vavle is new. I'll check and see. Thanks for the reply.
Old Oct 24, 2007 | 12:32 AM
gary c's Avatar
Gotta Leak........?
This happned to me when I had my Volks installed. Volks have stickers inside
the rim and one of them was too close to the lip causing my tire to have a
very slow leak. They found it by dunking the tire/wheel in a vat of water and
looking for bubbles to locate the problem.....anyway by dunking the tire
the problem shows up quickly and can be fixed!
Old Oct 24, 2007 | 10:35 AM
BW350GTskyline's Avatar
bent rim
my right front rim is bent slightly and i do face problems in filling it up ever so offten.. could that explain when i drive on the highway i hear almost like a loud humming noise..
Old Dec 8, 2007 | 01:20 PM
ALSHUBCAPS's Avatar
WHat you want to check is the valve pin, the tire, the wheel for dents, cracks, & the bead if they are corroded & if that doesn't do it check for what is called a porosity leak in the barrel of the wheel.
If all that fails, junk the car & buy a yugo.
Old Dec 10, 2007 | 10:21 AM
ALSHUBCAPS's Avatar
OF course that can cause a leak & vibration. you need to get it fixed & rebalanced, preferably road force balance.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Fireman07603
Aug 9, 2015 06:00 PM
joedaddy1
Jul 28, 2015 02:58 PM
