Winter Tires and Wheels
Old Oct 22, 2007 | 05:33 PM
The-Dream's Avatar
I'm planning to drive my coupe this winter when the snow is plowed and the weather isn't too bad. I was thinking between these wheels, do you think the wider is better? I'm not really asking about looks or diametre but rather what width would be better for winter wheels. I have my mind set on the 17s however. I have the H-Techs I hope that isn't too low for the winter.
RTX 155 - Silver 7.5"
Kosei Sniper Wheels 8"
OE Replica Mustang Cobra R Wheels 9"
I'm planning on running the Bridgestone Blizzak WS-60 Tires. 225-245/40 or 60?/17. Any suggestions? Last question, is it okay if I move away from the staggered set-up for the winter?
Old Oct 22, 2007 | 05:38 PM
redlude97's Avatar
Narrower tires are better for winter, and I would personally run the narrowest wheel that worse with those width tires. If you are going to be running 225 widths, I would use the 7.5 or 8" wheels, whichever is cheaper. 9" is going to need a minimum of a 235/245 which is not an ideal size for winter tires
Old Oct 22, 2007 | 05:39 PM
Jeff92se's Avatar
Red Card Crew
^ what he said. Wider is good for dry. But worse for snow.
Old Oct 22, 2007 | 05:40 PM
The-Dream's Avatar
Do you think it would be better to use 7" wheels then?
Old Oct 22, 2007 | 05:45 PM
The-Dream's Avatar
I think I'll get these then.
http://www.1010tires.com/wheel.asp?w...e+5+%2D+Silver
Running on 215/55/17, does this look better?
Old Oct 22, 2007 | 05:47 PM
redlude97's Avatar
7" is fine, I run 17x7 on 225/50/17 and 235/50/17
Old Oct 22, 2007 | 05:49 PM
Jeff92se's Avatar
Red Card Crew
You willing to buy used?
https://g35driver.com/forums/archived-sales/183479-17-asa-wheels-coupe.html
Rears might be a TAD short but should work. There are more than a few guys selling their winter wheel/tire setups right now
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bjo16
Aug 4, 2015 09:52 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
multimut
Canada
Jul 26, 2015 08:43 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
