Car is shakin with me new GT3s HELP
Old Oct 30, 2007 | 01:58 PM
TIAN's Avatar
Hold The Line
I sold my 19 OEMs and bout some 18'' SSR GT3s. 265 in the rear 245 in the front.
The car is shakin at 40+ and when I brake it vibrates a whole lot. I figured I just needed a balance but I have a shop tell me that its cuz my rear tires are bald.
Any ideas on what my issue may be?
Old Oct 30, 2007 | 02:11 PM
ShanesG's Avatar
Tires...
Maybe A Bent Rim...
Old Oct 30, 2007 | 02:17 PM
istan's Avatar
Hub Rings?
Old Oct 30, 2007 | 02:50 PM
TIAN's Avatar
Hold The Line
Originally Posted by ShanesG
Tires...
Maybe A Bent Rim...
Tires.... Maybe... im lookin into that
Bent rim... I hope not.. Didnt see anythin.
Hub rings... hubcentric ring was removed
Old Oct 30, 2007 | 03:23 PM
ShanesG's Avatar
even a small dent can cause that, i had a bent rim on my civic and loking at the rims they looked perfect, but after like 80mph it got pretty shaky, and it wasnt the tires, but yeah hopefully its not that
how old are your tires?
Old Oct 30, 2007 | 03:41 PM
istan's Avatar
Huh? Why removed?
Old Oct 30, 2007 | 03:52 PM
TIAN's Avatar
Hold The Line
The SSR GT3s had em and they wouldnt sit right on my coupe (05) He had an 04 and it felt fine on his car with the hubcentric rings. So I doubt its a dent. A shop told me the rear tires are too bald. I dont know what it is. I just want to get em balanced.
Old Oct 30, 2007 | 04:07 PM
express705's Avatar
i told you to buy my rims.......
Old Oct 30, 2007 | 04:10 PM
izmir41500's Avatar
G35driver Addict
you prolly need new hubcentric rings
Old Oct 30, 2007 | 04:18 PM
RANC3R's Avatar
yea its either centric hub rings or a diesel size bubble in the tire (which you said is imposssible bc of the baldness of the tire) unbalanced rims wont shake at 40mph usually around 50-60+
Old Oct 30, 2007 | 09:52 PM
TIAN's Avatar
Hold The Line
Do u think I should place the rings back on? I mean everyine is tellin me that its due to the baldness? He was running smooth with the wheels and he had the rings on. He also has an 04. My rotors has an extra bolt for who knows what and it wouldnt sit right. So we popped off the rings. I dont know what 2 do
Old Oct 30, 2007 | 09:56 PM
StreetChase's Avatar
PUT THE RINGS BACK ON!! you will seriously damage not only your wheels but also your hubs!
Old Oct 30, 2007 | 10:12 PM
bull3t's Avatar
yea it's your hub rings...why would you take them off? 04 and 05 are both 66.1 so they should fit...I just read one of your posts and you're supposed to remove
that nipple/bolt on your hub...it's there so you don't place rear oem rims on the front if i remember correctly...
Old Oct 30, 2007 | 11:28 PM
TIAN's Avatar
Hold The Line
****... i'll do it 2morrow morning. So thats prob the reason. When my friend mounted them he said it didnt sit flush so we popped em out. Since im not much of a wheel guru I went with it. OK so i'll do that and update u guys. Thanks for ur help!!
Old Oct 31, 2007 | 12:03 PM
(>")> G35's Avatar
Yeah, they more than likely left that stud on.
