TPMS question when upgrading rims
Old Nov 5, 2007 | 12:00 PM
nyckid's Avatar
If you have the stock 17's and you upgraded to the stock 19's, do you have to buy the TPMS? tire pressure monitor sensors? or can i use the ones that came with the car for my 17's?
Old Nov 5, 2007 | 12:07 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
You can use the ones that came on the 17's. You might have to go to the dealer to get it reprogrammed, but that's no big deal.
-GP-
Old Nov 5, 2007 | 12:10 PM
93 til Infiniti's Avatar
-GP-
^+1
Old Nov 5, 2007 | 12:20 PM
nyckid's Avatar
ok thank you!
Old Nov 6, 2007 | 08:40 AM
Byteman's Avatar
I'm missing something .. why do the TPMS need to be re-programmed when all he's doing is just transferring the sensors from the old set of rims to the new rims?
thx
Old Nov 6, 2007 | 10:50 AM
Gilley's Avatar
Just keep the TPMS in proper order to the new wheels and they won't need to be reprogrammed. ie. right front to right front, right rear to right rear.
Old Nov 6, 2007 | 02:00 PM
Scrooge's Avatar
On alldata it really doesn't say which wheel it needs to be put on. I think you can mix match them. Correct me if im wrong, but tell me why.
Old Nov 6, 2007 | 02:10 PM
GEE35FX's Avatar
I rotated my stock rims and the sensors still worked great, did not have to re-calibrate.
Old Nov 8, 2007 | 10:45 PM
THE ONE's Avatar
GEE35X is right. I did the same --- no problems too!
Old Nov 13, 2007 | 12:00 PM
nyckid's Avatar
exactly where are these sensors located? i took off my rims and didn't notice anything, is it something that is suppose to be plugged in?
Old Nov 13, 2007 | 12:18 PM
Gilley's Avatar
They are part of the valve stem. Look at the valve stem on the inside of the rim and you will see the black boxes, unless you have an 03 sedan. TPMS wasn't available in 03.
TheKnite
Aug 14, 2015 07:59 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Kal Hamm
Jul 24, 2015 08:55 AM
EasySausage
Jul 14, 2015 11:17 PM
