350Z NISMO wheel offsets?
Old Nov 25, 2007 | 11:59 AM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
does anyone know the offsets of the 18x9, 19x10 wheels off the 350Z with the NISMO package? thanks.
Old Nov 25, 2007 | 03:48 PM
HiTechOilCo's Avatar
I will assume you are referring to a stock set up, so if you call your local dealers parts department, they can provide you with this information.
Curious though...why are you looking for this information?
Steve - Hi-Tech Oil Co.
B.F.Goodrich T/A Certified Tire Specialist
Old Nov 26, 2007 | 07:15 AM
DRG35R's Avatar
20 Year Member
the Nissan/Infiniti dealer here is not very helpful with that kind of info.
I saw a NISMO Z on the lot and liked the gunmetal wheels and was thinking of getting a set.
Old Nov 26, 2007 | 07:49 AM
GEE35FX's Avatar
Here you go:
2007 Nismo Rims 2007 Nismo 350Z WheelsThese wheels come on the 2007 factory edition Nismo 350Z. They have a gunmetal finish and a stout 5-spoke design.
2007 Nismo 350Z
Super-light Forged Aluminum Alloy
Front
Offset: +30mm
Weight: 21 lbs 4 oz
Tire: Bridgestone RE050A 245/40/18
Rear
Offset: +30mm
Weight: 29 lbs 8 oz
Tire: Bridgestone RE050A 265/35/19
Old Nov 26, 2007 | 10:03 AM
DRG35R's Avatar
20 Year Member
Originally Posted by GEE35X
Here you go:
2007 Nismo 350Z
Front
Offset: +30mm
Weight: 21 lbs 4 oz
Rear
Offset: +30mm
Weight: 29 lbs 8 oz
Oustanding info! Thanks for your help!
Old Nov 26, 2007 | 10:28 AM
G35_TX's Avatar
Unless you want to pay $1500 a wheel, I doubt you will own a set.
Old Nov 26, 2007 | 03:57 PM
DRG35R's Avatar
20 Year Member
you are correct. squashed.
Old Nov 26, 2007 | 04:35 PM
Unless you can find a used set at ---> www.Car-Part.com
Good luck with it.
Distributing industry leading AMSOIL synthetic motor oils for over 20 years.
Old Nov 26, 2007 | 08:32 PM
GEE35FX's Avatar
If you keep your eyes open used sets come up. There was a set of 18/19" 350Z Grand Touring Rays Track wheels that sold this month in our area on one of the sites. It sold and he was asking $1500 for the set + tires.
These rims are also similar to the Nismo rims they were on the 2006 and 2007 350Zs with the Track and Grand Touring trim packages and the fronts were 18 x 9 and the rears were 19 x 10"
Old Nov 26, 2007 | 08:44 PM
redlude97's Avatar
Yup, same specs are the nismo wheels, but silver in color, and they have 3 dots on each spoke rather than the line on the Nismo's. They are much easier to find and cheaper since the NISMO Z's are limited edition
Old Nov 26, 2007 | 09:01 PM
GEE35FX's Avatar
Yes, here is a pic of those wheels, personally, I like these better :
Here is a pic of the Nismo 350Z wheels:
Old Dec 7, 2007 | 10:56 PM
Turbo Drifter's Avatar
I have a chance to get a set of the 19" 350z track wheels for my 04 sedan. I really like the idea of 19x9 and 19x10 wheels on my car. It will finish off the OEM sport look very well.
I am prepared to do rear fender rolling and fit a slightly smaller tire to make them fit if need be.
Has anyone tryed this or have any other imput on it.
Thanks,
Jeremy
Old Dec 8, 2007 | 09:44 AM
DRG35R's Avatar
20 Year Member
Thanks,
Jeremy
what are the offsets? if I am correct, I think they are the same as listed above for the Rays forged wheels I asked about.
if so, then these will not even come close to fitting on your sedan, even if you roll fenders. most guys runs 8.5 in front and 9.5 in rear. 9 and 10 will not fit unless offsets are very high and even then I am not sure because you may run into issues with hitting the suspension.
your best bet for a sedan is to 19x8.5 with approx. +38 offset in front and 19x9.5 with approx +45 offset in rear with 245-35 and 275-30 tires. this way you will not have any issues with rubbing and having to roll fenders.
I use to own an 03 sedan and went throught this already. good luck.
Old Dec 8, 2007 | 09:58 AM
GEE35FX's Avatar
You are correct, they are the same offsets as the 07 Nismo Z rims, 30mm front and back..
Old Dec 8, 2007 | 01:30 PM
DRG35R's Avatar
20 Year Member
thanks for confirming. no you know for sure they will not fit.
+30 F and R with 9 and 10 inch rim is kind of conservative for coupe, but would be sticking out past fender line on sedan.
