Wheel Spacers
Old Nov 29, 2007 | 10:30 AM
Kuneff's Avatar
Wheel Spacers
I am thinking about putting some spacers on my Coupe. I would like to get a little beefier stance. I am on a low budget.
I have searched and search and cant find much on spacers. I know I had seen thread before saying what size most people recommend and have used, but I cant find them now. Any advise or pics would be greatly appreciated. I have the 18" stock wheels.
Thanks in advance.
Old Nov 29, 2007 | 10:46 AM
Calvin's Avatar
Overglorified Altima
20/25
here is 15 front, 20 rear.
https://g35driver.com/forums/attachm...4&d=1160793460
https://g35driver.com/forums/attachm...0&d=1160793433
https://g35driver.com/forums/attachm...8&d=1160793642
https://g35driver.com/forums/attachm...0&d=1160793642
https://g35driver.com/forums/attachm...1&d=1160793662
https://g35driver.com/forums/attachm...2&d=1160793662
those are still tucked, IMO.
even he realizes he could have gone more.
Originally Posted by dTor
Hellz yeah man! I think if I had to do it over, I'd go with 20/25 myself.
Old Nov 29, 2007 | 10:48 AM
MixturePinoy's Avatar
you sure calvin?? I think Hai said 15/20?
Old Nov 29, 2007 | 10:50 AM
Kuneff's Avatar
Originally Posted by aHero4Eternity
20/25
Thanks Calvin, Now with those spacers being small/thin, will I have to cut my stock lug studs down? Any tricks to making them work/fit better? I am guessing that Iwill have to go with bolt-on adapter style spacer to keep it safe, correct?
Old Nov 29, 2007 | 10:53 AM
correct. there's no cutting'
Kuneff's Avatar
I am wanting a better look, but I dont want them out so far that they rub when I hit bumps for have people in the back seat. I delt with that on my Mustang when I had Cobra R's on it, and I dont ever wanna go thru that again.
Old Nov 29, 2007 | 10:55 AM
Calvin's Avatar
You willing to roll modify your rear fenders?
fyi i edited my first post with pics.
Old Nov 29, 2007 | 10:56 AM
Kuneff's Avatar
Are you sure you dont have to cut the stock lug studs? I put 1"(approx 25mm) spacers on my 03 Ranger, and I had to cut about 1/4" off the stock studs. Wouldnt I have to cut something off if I am only using a 15-20mm spacer?
Old Nov 29, 2007 | 11:00 AM
Kuneff's Avatar
I rolled the lip on my Mustang, so I am not affraid of doing it again. Got any pics of what the 20/25's look like????
Does the excess of the stock lug studs run into the back side of the oem wheels?
Old Nov 29, 2007 | 11:09 AM
Calvin's Avatar
I don't think I understand your question. excess of the stock studs? if you're putting wheel spacers on, then you're essentially losing stud length. in which case you'll need to extend the studs.
http://optionimports.com/ns-50220-a059.html
http://optionimports.com/ns-50225-a060.html
^^^extended studs are included
http://optionimports.com/kiwhsp5x1120.html
http://optionimports.com/kiwhsp5x1125.html
^^^come with longer studs already attached to the spacers
Old Nov 29, 2007 | 11:31 AM
Kuneff's Avatar
With the second kind. To me the safest kind. You actually slide it over your stock studs and bolt it to your hub. Then the stubs that are bade into the spacer is what you bold your wheel to.
Here is the issue... Your stock studs are usually longer than 20-25mm. they are are closer to 30mm (i believe). So there is an extra 5-10mm of the stock stubs that stick out past the spacer, which is basically the Hub at this point.
Where does the excess stock stud go? is the back of the stock wheels have an open hub area? or do they need cut? The pic below is my aftermarket snow tires. The open area beside each lug hole is where the extra stud could go, BUT does the stock wheel have the same open area between the lug holes?
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
