Wheel studs
Old Dec 6, 2007 | 05:17 PM
Jason@Riverside's Avatar
Yes, I have NISMO Longer Hub Bolts...
They come 50mm and 60mm... The Rears are about 35mm stock... fronts are about 40mm stock...
Old Dec 6, 2007 | 05:21 PM
ttrank's Avatar
Grocery getter
Hmm, 15mm/10mm may be too long. Let me check to see.
But how much are they?
Old Dec 6, 2007 | 05:26 PM
ttrank's Avatar
Grocery getter
Looks like the 50's will be ok.
Now how much are we talking?
To AZ 85085?
Old Dec 6, 2007 | 06:14 PM
50 or 60mm NISMO Hub Bolts are $65 per 10 pack plus shipping...
Old Dec 6, 2007 | 07:02 PM
ttrank's Avatar
Grocery getter
I thought you guys would be cheaper than that.
Old Dec 6, 2007 | 07:41 PM
They are pretty expensive to start...
I can get Ichiba Extended hub bolbs which are much less...
Old Dec 6, 2007 | 08:16 PM
Texasscout's Avatar
Jason, I have to put 5mm (0.2") spacers on the front of my 2005 sedan to make the M45 sport wheels clear everything. Do I need to replace the studs?
BTW, I bought 2 Ichiba 5mm spacers that come with longer studs for $60
http://optionimports.com/ns-50205-a056.html
Old Apr 3, 2008 | 11:48 AM
kingrukus's Avatar
....back from the dead...
is it possible to install extended studs without removing the rotors?
Old Apr 3, 2008 | 12:01 PM
caelric's Avatar
I installed extended studs without removing the rotors, but I do have the Stoptech BBK. Not sure if the stock brakes would make a difference or not.
Old Apr 3, 2008 | 12:07 PM
redlude97's Avatar
it would be pretty hard to install the studs without removing the rotor, its way easier to pull the rotor so you can easily maneuver the extended studs into the hub holes. I'm not even sure how its possible
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
si_driver
Jul 14, 2015 12:29 PM
