Wheel studs
Old Dec 2, 2007 | 07:22 PM
grifter91's Avatar
Wheel studs
I tried searching, but came up empty.
Have any of you replaced wheel studs on the G35 yet? I've done it on other cars not too bad, but I wonder how it is on the G.
Old Dec 2, 2007 | 07:36 PM
Jason@Riverside's Avatar
Its not to bad at all really...
have to remove the caliper / rotor and then you can tap them out / pull them through the hub...
Do you already have the studs?
Are you using OE length or extended hub bolts?
Old Dec 3, 2007 | 12:36 PM
grifter91's Avatar
Thats what I figured. No I haven't picked up the studs yet. I would use OEM's not extended.
I have no problem doing it myself, but its starting to get cold. The local infiniti dealership is asking for $150 for one stud.
Old Dec 3, 2007 | 02:32 PM
WHAT?!
Each stud is like $2.85 at most... plus shipping from me...
Maybe they are charging 1.5 hours labor with it?!
Old Dec 3, 2007 | 05:09 PM
johnparkyourcar's Avatar
are the studs what you screw the lug nuts into? my rims recently got attempted-stolen and so my lock was halfway screwed out and it was jammed in there so i couldnt screw it back in or out. so right now i have 3 out of the 5 studs and when i called a shop he was asking 60 bucks for each stud and to install it would be somewhere in the 100s for each stud!
Old Dec 3, 2007 | 05:16 PM
they are really easy to install... just have to take off the caliper / rotor. . they tap out / pull through the hub...
yes they are what the lug nuts bolt on to...
Old Dec 3, 2007 | 06:24 PM
grifter91's Avatar
Its totally labor time. When I did it you rent out the stud puller and bam its done. The problem is my nut is spinning on the bolt and I don't want to split it to get it off.
Old Dec 3, 2007 | 06:29 PM
why rent a stud puller?
get an open ended lug nut and some washers
Old Dec 3, 2007 | 06:40 PM
ReBirth's Avatar
um i bought them from my dealer at the price Jason said.
However i couldn't get my rotors off so i had to take it to my body shop to replace the studs
Old Dec 3, 2007 | 06:48 PM
front or rear rotors?
if rear... was your ebrake on?
Old Dec 3, 2007 | 07:19 PM
ReBirth's Avatar
^ It was the front rotors. Come spring time i will try to do the rotors all around 1 more time.
Old Dec 3, 2007 | 10:10 PM
grifter91's Avatar
Rotors.... hate them.
I changed my rear brakes recently the rotors were a mother's *** to try and take off. It took a half a can of WD40 and a rubber mallet to get it off. I was just about to give up when all of a sudden it slide off by itself. I used some anti-seize lubricant let's see how it works out.
The stud puller makes it easy. Especially now in the winter there is a ton of contraction going on further making it difficult. Keep in mind here in the NE we are at about high 20's into 30's.
Jay I will definitely get back to you. Perhaps to buy other parts too. I may need to get front brake pads and rotors as well. OEM.
Old Dec 5, 2007 | 08:36 PM
can i order some studs from you? 3 shipped to 92612
Old Dec 6, 2007 | 05:03 PM
of course! sending PM...
Old Dec 6, 2007 | 05:16 PM
ttrank's Avatar
Grocery getter
Jason, can you get longer studs? My new brake hats are thicker and I need ~5mm longer studs.
