Alignment on TEIN BASICS (coupe)
Just got the G aligned and they said that the best they could do was get it 1 degree off stock specs. Is this a good enough setting or should i raise the car more to get it back to stock specs. Will 1 degree be a problem or is it something most won't bother to fix. Thanks for the feedback- Peace
Re: Alignment on TEIN BASICS (coupe)
What are your specs alignment specs at after they were done? Toe and camber.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Edmund Burke
G35 6mt
They didn't say much, only that it was 1 degree off of spec. They said I should buy a camber kit to fix it but I don't know if I want to spend money on that. hehe
Well it would be nice to know, sure sound's like it's camber.
Coupe specs fall in the range of +0.3 to -1.3 camber in the front. But, to adjust the front, will cost allot more than the rear.
The rear specs allow for -2.0 to -1.0.
You really should find out the numbers from the alignment shop. If your rear camber is at -3.0, yeah you've got to do something about that. Best way to fix is to by a set of LSDunique rear camber arms, also sold under the Kinetix brand, they cost $219.99, I have them on my car, highly recommened here.
http://www.kinetixracing.com/index.a...WPROD&ProdID=2
Curious, how far did you drop the car?
Edmund Burke
G35 6mt
Edmund Burke
G35 6mt
I would get ahold of them and get the exact alignment specs (if you still can). For future reference try to always get a copy of your alignment sheet with the before and after specs.
If your out a whole degree then that's alot and will probably eat tires up pretty good.
G35C Blk, 6MT, Lthr, Aero, Prem,
-1 should be fine all around.why not buy the toe and camber bars?Stillen/Kinetics/Evo whatever.
Dark Side Of The Moon
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
