19" or 20"
Old Dec 3, 2007 | 05:09 PM
2fast's Avatar
19" or 20"
what are advantages/disadvantages of picking 19 over 20"
Old Dec 3, 2007 | 05:16 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
its all personal interest. some people like the look of 19's more than 20's.. and vice versa. With 19's you can get more meaty tires if you have bad roads, 20's will have a lower profile tire and you'll feel the bumps in the road more. 20's will fill up the wheel well with more rim instead of more tire.. there's plenty of different aspects between both sizes.
-GP-
Old Dec 3, 2007 | 05:22 PM
2fast's Avatar
i understand but in terms of performance which is better
Old Dec 3, 2007 | 10:47 PM
06PlatinumG's Avatar
If you what performance go with an 18" wheel. The smaller the wheel the less weight and rotational mass, which will also help with braking
Old Dec 3, 2007 | 10:51 PM
ttrank's Avatar
Grocery getter
The only reason I would do it is weight. 20's look better.
Old Dec 4, 2007 | 12:19 AM
SDGeneralCounsel's Avatar
20's also offer a rougher ride and they significantly hurt the performance of the G. 19's are pretty much the perfect size if you consider all factors
yes and no. according to your theory you would get same results with a lighter weight 19" set of wheels.
Old Dec 4, 2007 | 12:32 AM
Kazaam's Avatar
Tires for 19s seem more expensive IMO
Old Dec 4, 2007 | 12:49 AM
Beebo's Avatar
they are...
i say go with 18's or 19's for Performance
Old Dec 4, 2007 | 01:20 AM
BlueDevilBAMF's Avatar
^Agreed... in terms of tire cost the difference between 19s and 20s seems to be negligible more often than not. Also, IMO you sacrifice more performance by going from 19 to 20 than you do from 18 to 19 with the G Coupe.
Old Dec 4, 2007 | 05:03 AM
G-MENTED's Avatar
stick with 19s.
