245/40/18 winter?
Old Dec 13, 2007 | 10:01 PM
NJzFinestG's Avatar
245/40/18 winter?
will 245/40/18 all around work on my g coupe for winter tires?
thanks
mike
Old Dec 14, 2007 | 10:06 AM
lowrider's Avatar
It will throw VDC and TCS off. The 245/40/18 is OK in front, but keep 245/45/18 in back.
Comment: For winter (snow) driving you want to keep narrower tires on the vehicle than you do in the summer. So 225/45/18 might be a better choice for the snow, but I know that 225/45/18 might be a hard size to find, so, as I said, 245/40/18 would be OK because it would fit fine on your wheel and is the same diameter as the 225/45/18.
Lou
Old Dec 14, 2007 | 10:29 AM
NJzFinestG's Avatar
so will it throw the vds and tcs off?? i found a set of 225/45/18 all around but someone said the same about that. so i passed on it. im thinking the 245/40 should be ok since its closer to 245/45
Old Dec 14, 2007 | 10:43 AM
GEE35FX's Avatar
Mike you should have purchased the 225s, the 245/40/18s are worse. The 225s are much closer to your stock size than the 245/40/18, which are 1" different in Outside diameter than your OEM size or 3.6% out. The 225/45/18 tires were 2.7% out from your OEM rear tires.
Wayne
Old Dec 14, 2007 | 10:47 AM
GEE35FX's Avatar
Here Mike, You can figure it out.
Here is a good tire size calculator I use: Tire Calculator and Comparator
Old Dec 14, 2007 | 04:41 PM
NJzFinestG's Avatar
maybe ill just have to resort to reg oem specs. i cannot find ne 1 running these sizes either. most that i searched thought about it but ended up getting the oem spec tires.
04G35NYC
Winter Setups
34
Jun 2, 2016 09:12 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
Learned Hand
Oct 1, 2015 09:02 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
