245/45/17 Tires on a Sedan
Old Mar 11, 2004 | 08:23 AM
mountain's Avatar
Ok....I know this has been asked before. G35 s came with 215/55/17 i burned them up and went with 235/45/17 S03's. I have burned them up (only have 16k miles but that is what club racing does). I was wondering if 245/45/17 will fit the stock sport wheels without rubbing.
Who knows for sure???? Please, I gotta order new tread I runnin on slicks!
Thanks for the help
Old Mar 11, 2004 | 11:08 AM
ryoken's Avatar
Re: 245/45/17 Tires on a Sedan
Technically, 235/50 or 245/50 fits the 17x7 rims, but 245/45 requires a 17x7.5 rim. That's technically, according to the tire manufacturer's specs.
Lead_foot has been autocrossing Falken Azenis in 245/45R17 on 17x7's for a while. PM him, or maybe he'll see this and post his take on them here. He says they work great.
It took me 10k miles to run the original Bridgestone Turanza's down to the wear bars, and I'm autocrossing regularly too. Time for some better rubber -- but then I won't have anything to blame my bad times one. [img]/w3timages/icons/smile.gif[/img]
Old Mar 11, 2004 | 12:31 PM
Gsedan35's Avatar
I guarantee they will not rub. I'm running 245/40-18 on 8" rims with the same 45mm offset and I do not rub. 245/45-17 and 245/40-18 are extreamly close in rolling diameter and tread width, though I'd think a narrow rim would draw in the tire contact patch down via rounded shoulders.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Mar 11, 2004 | 02:35 PM
hotGspot's Avatar
I use 18x8.5 and no prob.
Nothing Turns You On More Than The "hotGspot"
Old Mar 11, 2004 | 07:31 PM
mountain's Avatar
oh yeah thats right...245's are too big for the stock wheels. I knew there was a reason I went 235's.
It probably makes handling worse then the 235's since there is more sidewall flex on the smaller wheels. I might just stick with the 235's. There just aren't as many selections at the 235 size.
Thanks for the feedback.
Mountain
Old Mar 11, 2004 | 08:44 PM
ryoken's Avatar
Try 225/55R17. You can get Bridgestone S-03 Pole Positions or Goodyear Eagle F1 GS-D3s in that size.
Old Mar 18, 2004 | 08:33 AM
user 4560487's Avatar
if you are club racing, go with the 245/45/17 Falken Azenis, while techncially they require 7.5 inch wheel, like others said, lead-foot and and another guy have run them without issue. The sidewall on the Falken's are very stiff, you won't have an issue. The Falkens do wear out fast, but they are cheap and grip like crazy. Search for 'Falken', lead-foot posted some pics of his on the stock rims, doesn't look like a bad fit at all...
Mize
Silver 03 6 Speed Sedan/Willow/Premium
Old Mar 18, 2004 | 11:03 AM
townsley's Avatar
Why not the Falken Azenis in the 225/45ZR17 size?
-townsley-
2003.0 Premium BS/Willow 5AT Sedan
ZTube/K&N Filter/Sport Suspension
Grounded/Tinted/Splash Guards
Lip spoiler/Aluminum Pedals
Battery Disconnect Switch
Old Mar 18, 2004 | 11:09 AM
ryoken's Avatar
The 245/45R17 is already 2.4% smaller than the stock wheel diameter. General rule of thumb is not to go beyond +/- 3%. 225/45R17 is 5.1% smaller than stock.
That would be okay for autocross days only, but you'd need normal size tires for daily driving, or you'd confuse the ABS/VDC systems and wind up with a rather large odometer discrepency compared to actual miles travelled after awhile. Plus, wider is better for handling. [img]/w3timages/icons/smile.gif[/img]
Old Mar 18, 2004 | 08:39 PM
what he said, plus wider is better, although that statement might start a debate,
Mize
Wish List:
18x8 SSR GT1 with 245/40/18 Kumho Ecsta MX
Springs/Shocks/Sway Bars
http://www.AutomobileFanatic.com
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
reaper76
Aug 5, 2015 10:13 AM
CJay
Aug 1, 2015 03:57 AM
BlackGee35
Jul 31, 2015 11:04 AM
