Is it ok to go with a 245/30/20 up front?
Old Jan 19, 2008 | 04:06 PM
GThIrtYFiZle's Avatar
Im running 285/35/20 in the rear. I am rubbing with the 255/35 so I was wondering if I shoulg go with this size? Any suggestions.
Old Jan 19, 2008 | 05:57 PM
bump. Or what should I go with?
Old Jan 19, 2008 | 06:00 PM
imalazeeass's Avatar
u should be running 255/30 and 285/30
Old Jan 19, 2008 | 07:00 PM
jserman's Avatar
yea a 255/30 would be better a 245/30 would be fine or a 245/35....
do your 285's in the rear RUB????
Old Jan 19, 2008 | 07:05 PM
No the 285' dont rub. I rolled the fenders tho, lol.
Old Jan 19, 2008 | 07:12 PM
jserman's Avatar
Don't tell me that......LOL
Old Jan 19, 2008 | 08:00 PM
Y? lol
Old Jan 19, 2008 | 08:33 PM
chester's Avatar
i run 255/35/20 up front... and 275/30 rear.. no problems unless i turn on a up hill drive way really fast the front will rub. just drive slow when turning, more rubber less road noise.
Old Jan 19, 2008 | 08:41 PM
redlude97's Avatar
Why are you running 35 series tires with 20" wheels? the correct sizes are 245/30/20 or 255/30/20 and 275/30/20 or 285/30/20
Old Jan 19, 2008 | 08:47 PM
chester's Avatar
its what i was told by a guy i know very well that is workign at mackin in cali, i have no problems with it. Untill i do i will stay with it lol
Old Jan 20, 2008 | 01:32 PM
Well I have known plenty of people that ran that size and they are completely fine with it. Its what people suggested for me from the start. I guess only problem is that the front dropped more then expected. and i still only rub certain times, when like said b4 going up steep driveway or so. And anyway i was running 24/35 b4 and 275/30 perfectly fine. Only problem is that these tires run bigger. I can fit 255 in theback perfectly on still not b stretched, beleive it or not. I may b able to roll my front fender and be good tho. If i do sell, am i better off goin with the 245/30 with the 285 rear? Cause I think this is what ill do since like I said these tires run bigger. but they grip sooo good and its still freezing out lol.
Old Jan 20, 2008 | 02:31 PM
chester's Avatar
u can run that size i don't see why not.. if my tires are bigger in the front by a tiny bit i dont' see why u can't do vise versa to keep ur front from rubbing.
Old Jun 27, 2008 | 08:47 AM
kgreene's Avatar
I run 245/35/20 in ft and 275/30/20 in rear. Dropped on s techs. Honestly I am just making clearance in the fender wells.
Old Jul 19, 2008 | 05:21 AM
heyitzalex's Avatar
is a 35 profile tire going to provide THAT much more protection against bends as opposed to a 30 profile?
I would think that as long as the PSI is the same, the difference is minimal. Maybe some can chime on that. A 245/30 tire is a little less than 0.5in thinner than a 245/35.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
miata007
Aug 17, 2015 04:36 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
