will i rub after rollin gmy fenders?
Old Jan 21, 2008 | 10:59 PM
chester's Avatar
i have 20x10.5 rear with 22 offset lowered on eibach pro kit.. currently running 275/30 with less than an inch from rubbing if i rolled and moved up to 285 will i rub? or clear it?
Old Jan 22, 2008 | 02:14 AM
redlude97's Avatar
you'll be fine with a roll. Plentt of room for clearance
Old Jan 22, 2008 | 11:03 AM
chester's Avatar
are u positive??? are u running the same set up or something? I was plannign to try that diy on rolling the fender
Old Jan 22, 2008 | 01:25 PM
redlude97's Avatar
I'm running a more aggresive offset and I still clear
Old Jan 22, 2008 | 09:58 PM
chester's Avatar
got a pic of the clearance on 285 by any chance? and ur lowered with 10.5 rear? whats ur offset?
Old Jan 22, 2008 | 11:23 PM
Deezflip's Avatar
25.4mm = 1inch....
your adding 10mm changing from 275 to 285, which is actually 5mm for inner and 5mm for outer.
5mm = .19inch and you said you have about an inch until it rubs. You might not even need a roll
Old Jan 22, 2008 | 11:45 PM
Deezflip's Avatar
ehh, i take that back...from the looks of other 20"x10.5 Volk GT-C owners with 275's, not even close to an inch clearance.
then there's this old post with some one with 285's and S-techs, he had to roll some fenders. Pictures didn't show, i guess it's a fairly old thread.
http://forums.freshalloy.com/showthread.php?t=107431
Old Jan 22, 2008 | 11:58 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
If you roll the fenders you'll have more than enough room to put on a 285 tire. I have a sedan and even i know this. You just need to know your width's and offsets. If you dont believe me or redlude, then that's your choice.
-GP-
Old Jan 23, 2008 | 12:06 AM
GLuXuRy's Avatar
just take it this way .. if it doesnt clear .. next step is a smaller tire
Old Jan 23, 2008 | 12:55 PM
chester's Avatar
yea its easy to say that gluxury but after buying new tires gotta buy new ones again for a smaller size then re mount them.. lol so it adds up its why i want to make sure before i take these steps.. Ill take a pic of my clearance.. and post.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
alinero718
Sep 27, 2015 09:35 PM
alexbenz
Sep 26, 2015 11:30 AM
