350Z H-Tech on Coupe experience, Camber?
Old Jan 22, 2008 | 09:33 PM
DRA-G35-ON's Avatar
Originally Posted by jiggafree
then i will be the second! i am dropped on Z h techs and my camber is -1.8 in teh fronts, and my garage said i need a camber kit as well. purchased both front and rear but havent put them on due to laziness
damn, and I was gonna get them just cause I didn't think I would need one.
Old Jan 23, 2008 | 03:53 AM
vash_g35's Avatar
Hi guys! Im new here in the forum and just bought a used 06' coupe. This is my first post, and I've been reading a lot of things since the last couple of days, and really helped me a lot! Great forum by the way
Anyways, sorry for the original poster for butting in, but i had to ask,.. I dropped mine using tein stech so now the neg camber is noticeable, my question is will it affect the driving/riding performance of the car for having a negative camber? If yes, can it be corrected by some sway/strut bar? (cheaper than buying a set of camber kits)
Thanks in advance!
Old Jan 23, 2008 | 09:48 AM
netcbc's Avatar
I was thinking this as well so it seem the conclusion seems you get 1.8-2.0 negative camber in the front and the back is not as bad?
Old Jan 23, 2008 | 09:49 AM
netcbc's Avatar
as well the flipping tires thing seems like a good idea
Old Feb 6, 2008 | 02:16 PM
tjlazer's Avatar
Some will tell you having negative camber increases performance, but too much is also not good. (over -2.0 degress)
Old Feb 7, 2008 | 04:04 AM
vash_g35's Avatar
Thanks for the info, I guess I'll keep the neg camber then. Saves me some cash to get other stuff for my G
Old Apr 7, 2008 | 04:19 PM
netcbc's Avatar
What about ride quality compared to stock? As well is how are the chance of blowing OEM stock/struts.
I have sport suspension. on my 2003 6mt
Old Apr 7, 2008 | 06:03 PM
tjlazer's Avatar
not noticible unless you get different springs, which will affect ride quality.. If you go too low you could adversly affect stock struts but that is more of a reason to upgrade to new stuts...
Old Apr 9, 2008 | 03:26 AM
chenG35's Avatar
Originally Posted by w0ady
get a camber kit! dropped on 350z h-techs with my stock camber adjustments maxed, i was still at -2 in the front.
-2 in the front when maxed? i'm not sure if it's different on other years but for my 03 the front cambers are not adjustable.. so i had to live with the -1.5 from the H-techs, which is lower than most ppl on this thread cuz my fronts are 8.5/+26 i think.. so in the end it depends on your offsets quite a bit.. if you are on stock 18's you probably don't need camber at all
Old Apr 18, 2008 | 06:33 AM
French87's Avatar
i just got alignment today and with my 350z htechs on 20's my fronts are -1.8/-1.6
rear got back into spec tho.
debating getting camber kit... was trying to avoid that
Old Apr 18, 2008 | 02:04 PM
jdmgee35's Avatar
From what I found, for the fronts, it's the toe that matters the most for tire wear.
Old Apr 18, 2008 | 04:49 PM
redlude97's Avatar
I'm on 350z h-techs and my front camber was at -1.9/-1.6 and I had the front toe set to 0.05 and I still get uneven wear on the front, so a camber kit in the front would not be a back idea.
Old Apr 18, 2008 | 07:45 PM
releasedtruth's Avatar
Crazy that 140 dollar springs get you into 600 dollars worth of camber equipment. I'm at -1.14/-1.32 in the front on stock suspension, -1.32/-1.58 in the rear. Now coilovers.... 1400-1800 + camber kits, yipes.
And yeah, I heard the toe and cross caster were important to wear. Previous owner cupped the right front tire with poor alignment.
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
Popes
Jul 29, 2015 05:07 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
