Will these tire size RUB?
Old Jan 26, 2008 | 09:43 PM
coolbratva's Avatar
I have a coupe and planning to buy staggered 19inch rims. in the back 275/30/19 and in the front i am not sure i am looking at 245/40/19 and was wondering if its going to rub the fenders or anywhere else? Cause I keep seeing everybody gets 245/35/19. Also, car is all stock.
Old Jan 26, 2008 | 09:47 PM
MIA BlazinVQ's Avatar
brb getting cut
No. stock sidewalls are 40 series so you should be good.
Old Jan 26, 2008 | 11:14 PM
redlude97's Avatar
why would you run that size in the front? Those tires are really mismatched, the rear is going to be way shorter than the front tire
Old Jan 27, 2008 | 07:12 PM
coolbratva's Avatar
I just got a good deal on the back tires, and the front tires i can get good deal too. Do you think the front will sit higher than the back that will be visible?
Old Jan 27, 2008 | 07:30 PM
Sbeck's Avatar
Get normal sizes imo.
Old Jan 27, 2008 | 07:34 PM
06PlatinumG's Avatar
Those tires don't match at all. The 245/35 has a dia. of 25.8 and the 275/30 is 25.6. You should try and match stock tires as close as possible, front 26.1 and rear 26.7. You need to check tire spec's before you buy. Tirerack has most tire spec's posted.
Old Jan 27, 2008 | 11:44 PM
Triple8Sol's Avatar
Terrible selection all around. Don't buy those fronts, and get the right size.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
Jnm07
Aug 6, 2015 03:03 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
