Longer wheel studs
Old Feb 27, 2008 | 02:56 PM
Drewer's Avatar
Longer wheel studs
For those with spacers, etc, how do you get the longer studs in? I used a rubber mallet to pop the OEM ones out, but I can't seem to press the new ones completely in and don't want to damage them. Anyone have any pointers? Thanks!
-andrew
Old Feb 27, 2008 | 02:59 PM
Jeff92se's Avatar
Red Card Crew
Well I don't know the "offical" way but if you put a spacer on the stud and thread in a big bolt, won't that pull the stud in?
If that doesn't work, I wonder if heating the spindle with a propane torch and throwing the studs in ice overnight would gain you enough clearance to pop them in?
GreenGoblin's Avatar
The goblin resurrection
quick tip leave the studs in the freezer for a couple hours it will contract them making them a hair smaller then, they should be able to pop in with the mallet
redlude97's Avatar
Use a stack of washers and an open ended lug nut to pull them through, or do it the ghetto way like Pat and I and use a stack of closed end wrenches LOL
Old Feb 27, 2008 | 03:05 PM
Drewer's Avatar
Sweet deal y'all! Thanks for the help!
Old Feb 27, 2008 | 03:15 PM
waijai's Avatar
i.love.gold
I just put a deep socket on there with lug nut and zapped it w/ the air tools to pull the studs through.
Old Feb 27, 2008 | 03:17 PM
ttrank's Avatar
Grocery getter
I used the closed end of a wrench, and a deep socket on my impact to get them on.
Old Feb 27, 2008 | 04:12 PM
FlyingLumpia's Avatar
I did the ghetto way too. LOL
Old Feb 27, 2008 | 04:14 PM
MixturePinoy's Avatar
Just lube up your studs and talk dirty to them
Old Feb 27, 2008 | 04:50 PM
lol get in beotch
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
si_driver
Jul 14, 2015 12:29 PM
