Mods needed for 19" rims
Old Mar 17, 2008 | 06:21 PM
GNEU's Avatar
I am planning on getting 19s for my 06 coupe, what are the mods i have to make to fit those???
Yes I am a noob.
Old Mar 18, 2008 | 07:35 PM
tjlazer's Avatar
The only mods you need is to not be a n00b. 19's fit on stock G35's, even came as stock on the 6MT!
Old Mar 18, 2008 | 07:39 PM
redlude97's Avatar
Lower first, then get aftermarket wheels. OEM 19's are okay at stock height
Old Mar 18, 2008 | 07:42 PM
Dakkerz's Avatar
Are you planning on after market 19's or the OEM 19's, you didn't really specify? If you're going after market and are lowered, depending on the offsets and how much you lower the car you may need to roll the fenders.
Old Mar 18, 2008 | 08:13 PM
GNEU's Avatar
I'm planning on gettin aftermarkets...
Old Mar 18, 2008 | 10:14 PM
Dakkerz's Avatar
Just keep offsets and widths in mind. Also if you lower your car, depending on how low you go you may also need a camber kit if you plan on keeping alignment within spec.
Here's a link to get some ideas.
https://g35driver.com/forums/wheels-tires/205511-ultimate-wheel-offset-thread.html
You can search through the Wheel and Tire section for more info
https://g35driver.com/forums/forumdisplay.php?f=184
Good luck.
Old Mar 18, 2008 | 11:00 PM
GNEU's Avatar
Thanks! u rock!
Old Mar 19, 2008 | 01:07 PM
Dakkerz's Avatar
Thanks! u rock!
NP just post up pictures of the new rims when you get them on
Old Mar 19, 2008 | 06:47 PM
tjlazer's Avatar
If you do get OEM 19's, get some 15/20mm spacers, you will love the look.
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
nervseele
Texas
Jul 29, 2015 08:49 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
vstypicals
Jul 20, 2015 10:55 PM
