Tire Size ???
Old Apr 3, 2008 | 10:46 PM
OU812G350's Avatar
Tire Size ???
can or has anyone changed tire sizes on oem 19's?? can u put 245/40/19 on the front replacing 225/40/19...and put 265 or larger on the rear.. i dont know about clearance but i would like to protect the rim lip better...i see so many 19's on cars with lip rash. 3 of the 4 rims on my wifes are scared....... thanks--
Old Apr 3, 2008 | 11:04 PM
Beebo's Avatar
yes you can put 245/40/19 on the front rim.... i have 245/40/19 front and rear... no VDC problems at all... now 265 or larger in the rear would not be safe... 255 is the best IMO...
search there are plenty of threads to help you out
Old Apr 3, 2008 | 11:14 PM
OU812G350's Avatar
thanks i did not know about tire clearance in the front??? a tire guy told me 265 "should " fit out back
Old Apr 3, 2008 | 11:19 PM
Beebo's Avatar
the clearance is fine... 265-275 will fit in the rear but its just too wide for a 8.5 rim and not safe if you like to take corners fast
Old Apr 3, 2008 | 11:26 PM
Alpha Ice's Avatar
I did 275 35 19 on the rear and have had no problems yet. I was told that 285s would have problems. Ill be running 370 hp at the crank so I needed all the tread I can get in the back. They are a bit big in the wheel wells but don't stick out at all
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
