What size tires?
Old Apr 14, 2004 | 07:36 PM
B1ackmarket's Avatar
What size tires?
Hey guys, I got a set of 19" wheels in size 19x8.5 with a 29 offset and 19x9.5 with a 38 offset. What size tires do you recommend?
Old Apr 14, 2004 | 08:18 PM
lowrider's Avatar
Re: What size tires?
245/35/19 Front and 275/35/19 back are the correct sizes. You also might want to think about a spacer for that rear wheel. Try to move the offset out to something like +30mm.
Lou
Old Apr 15, 2004 | 07:58 PM
Would it rub if I run 40 in the front with 35 in the rear?
Old Apr 15, 2004 | 08:05 PM
lowrider's Avatar
No it wont rub, however you'd lose the stagger, which might upset the VDC. The car is designed around the stagger.
Lou
Old Apr 15, 2004 | 09:52 PM
whats worth more, the protection or keeping the stagger?
Old Apr 16, 2004 | 02:52 AM
iLLG35's Avatar
NY G-Squad G Race Driver
Im also having problems deciding also. I got 19x8.5 for all 4 rims with a +40 offset. i was thinking of going 245/35-19 all the way around so i can rotate tires because I dont have alot of money rite now to replace rear tires when they're bald. What will a 40 offset look like and will that be good on a G35 Sedan with sport suspension? And should I just go for the 245 front and 275 rear??? Thanks for your help, Martin
Wat'ssss Realllyyyy Goooodddd!!!!!
Old Apr 16, 2004 | 08:08 AM
lowrider's Avatar
Blackmarket
Keep the stagger. You can have your cake and eat it too, by eather running 18" wheels (as I do) all the way around or run 18s in the front and 19s in the back, as on the C5 Corvette.
iLL35
The sedan is not designed with a stagger. Run the same sizes front and rear, as with stock. Just pick out tires that have the same outer diameter as you current 17" wheel/tire combo.
Lou
Old Apr 16, 2004 | 08:38 AM
i can't run 18s, since I have a set of 19s sittin in the back seat :-).
vitamin.v
Nov 7, 2019 06:10 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
