Nitrogen filled tires - FTMFW!!!
on
Originally Posted by JOKER
what about pressure diff between hot and cold tires.
Originally Posted by G35sedan03
for what i've read, psi stays constant between hot and cold with nitrogen filled tires. It is not affected as regualr air is with expansion as it gets hotter. racing teams use hydrogen because it will maintain the psi either hot or cold.
![Confused2](https://g35driver.com/forums/images/smilies/confused2.gif)
The real reason for the more predictable pressure change is that the nitrogen is processed to remove almost all water vapour. The water vapour is what causes much of the pressure change during extreme heat cycles like race conditions. The difference is negligible in normal street driving.
Now I did have a friend that had a big 20# can of Freon 12 and he used it all summer to fill his old tires. Well Freon 12 has a boiling point of 75 deg F +/- and the first cold norther that came thru left all his tires flat.
![Icon17](https://g35driver.com/forums/images/smilies/icon17.gif)
on
here's one link to start with https://secure.powertank.com/truth.or.hype
and here's another http://auto.howstuffworks.com/question594.htm there should get some good answers.
<!-- / message --><!-- sig -->
#30
