Toyo T1R FTL
Old Jun 19, 2008 | 11:59 PM
  #31
redlude97's Avatar
how many of you have actually run the re050's in the same size as you are running the t1r's? I think alot of you would change your tune if you compared them on a similar basis
Old Jun 20, 2008 | 08:22 AM
  #32
falconey's Avatar
Originally Posted by Klubbheads
it sounds to me like u got a faulty tire.
I'm with you. There's no way the tires should be 'scary' at 34 psi.
Old Jun 20, 2008 | 08:28 AM
  #33
express705's Avatar
the only time my tire was scary was at 0psi.
Old Jun 20, 2008 | 08:30 AM
  #34
B L U E S L A T E's Avatar
Honda Accord
^What in the heck are you talking about? You can't even afford tires...
I though you were running your SC'd G with ONLY rims?
Old Jun 20, 2008 | 08:32 AM
  #35
express705's Avatar
naw man i can only affor these...
Old Jun 20, 2008 | 08:33 AM
  #36
Honda Accord
Oh shiznit!!! That's HOT!!!
Old Jun 20, 2008 | 08:34 AM
  #37
express705's Avatar
yea , 19.99 at discount tire.
Old Jun 20, 2008 | 08:46 AM
  #38
Nismo G's Avatar
Jello? I had bridgestones and they sucked *****. Talk about jello. The toyos are hard as a rock, which sucks for road noise, but they outperform the bridgestones no questions asked.
I am running Front 245/35/19 and Rear 285/30/19
Front tires haven't been rotated yet and have 23,000 miles on them and are still completely brand new. No camber wear at all and im lowered.
Rear tires have 23,000 miles on them and i rotated them after 14,000 miles and they still have about another 5,000 miles left on them. Very little camber wear.
So far other than the road noise, the toyo tires performance and tred wear have been perfect.
-Sean
Old Jun 20, 2008 | 09:00 AM
  #39
Nismo G's Avatar
I do want to try the nitto invo's though...
-Sean
Old Jun 20, 2008 | 11:22 AM
  #40
Klubbheads's Avatar
-Sean
decent tire but the downpart is that u can not rotate from side to side. So if u have over -2.0 camber like mine, im guessing they will take about half the time of T1Rs to wear out.
A friend of mine had those and Toyos before on his GTI and GTO, he told me the performance of the Toyos are better.
Old Jun 20, 2008 | 11:24 AM
  #41
Calvin's Avatar
Overglorified Altima
nitto neogen + -3.0 camber like me =
Old Jun 20, 2008 | 11:25 AM
  #42
Klubbheads's Avatar
^ur balling Calvin. I cannot afford tires every six months.
Old Jun 20, 2008 | 03:59 PM
  #43
ResIpsa's Avatar
Everybody calm down.
For starters, I was running the exact same size in the Bridgestone’s. However, my rears were run flats. I literally could drive with 0 psi in the tires and the sidewalls would not flex. Even the non-run flat’s have a very stiff sidewall. The construction of the Toyo sidewall and the Bridgestone are vastly different.
Everyone hates the RE050A’s because they are “hard as rocks.”
Maybe, just maybe, the reason I don’t like the Toyo’s is that I prefer a tire with a stiffer sidewall.
I’m sure that I will get used to the Toyo’s. But believe me, the sensation around corners is a little unsettling.
Old Jun 20, 2008 | 05:28 PM
  #44
shabarivas's Avatar
wait about 200 miles (or a few burnouts ) ... they should start feeling like rails... they are not as good as pole positions or advans... but for the price i feel they are VERY hard to beat
Old Jun 20, 2008 | 05:30 PM
  #45
shabarivas's Avatar
LOL @ replacing tires... stock tires = 10K miles backs are at 0 and fronts at about 10-20%...
on to 4 t1Rs and 22K miles - fronts have NO inside tread left... lmao replace fronts....
And of course... new rims = 4 new tires.... all w/ in 26K
