H&R Spacers, 15mm...does this look right? [Pics]
on
Hey guys,
My buddy just sent me pictures of his 15mm H&R Spacers he has on his G35 Coupe. I'm thinking about picking these up from him. In the pictures, it looks like the spacers are not the exact same size as the hub. It looks a little smaller. Is it supposed to be like that? If others with 15mm H&R Spacers could chime in that'd be awesome.
Front:
![](http://img.mypicgallery.com/jincar/front50.jpg)
Rear:
Front:
Rear:
![](http://img.mypicgallery.com/jincar/rear50.jpg)
on
Originally Posted by diablo1356
really? i saw a diy thread not too long ago where the guy had to remove a lot more than the wheels..what brand of spacer do you recommend? im a noob when it comes to spacers, but ive heard its good to have them with extended bolts(?) and for them to be hubcentric...
other spacers come with extended studs. the DIY you were looking at was probably one to remove the stock studs and replace them with the extended studs.
you definetely want spacers that are hubcentric. otherwise the weight of the wheels will go on your studs, not good.
Originally Posted by ChichiInSoCal
Just added the Kics Wide Tread spacers 20mm front / 30mm rear. But there is this screw on the front rotors that I don't know the purpose for. Does anyone know what this is for?
on
