help..ASAP, how wide can i go on stock rears?
Old Jul 29, 2008 | 06:01 PM
UpSideDownDesi's Avatar
so what's the widest one can go on stock 18's on the back without rubbing. Car has .9" drop in the back. I was thinking 265/40/18. Factory size is 245/45/18 for rears.
Old Jul 29, 2008 | 08:46 PM
volcom_koda's Avatar
If you can find a tire that you like that has 265 size go with it! I am running 255/45/18 rear and 245/40/18 front with Falken Azenis. I have a 1.2 drop and have no rubbing at all. You should be fine by a mile with that setup.
Old Jul 29, 2008 | 09:19 PM
you are also on stock wheels?
Old Jul 30, 2008 | 12:00 AM
yessir.
Old Jul 30, 2008 | 12:20 AM
got a pic?
Old Jul 30, 2008 | 12:29 AM
Ghayes23's Avatar
You won't rub with 265's on stock wheels.
Old Jul 30, 2008 | 09:55 AM
https://g35driver.com/forums/northwest/225919-southeastern-wa.html
First page, post #8.
Old Jul 30, 2008 | 01:09 PM
y'all think tires might be too wide of a tire for the wheel? I mean give it a squishy/squirmy feeling?
Old Jul 30, 2008 | 01:14 PM
redlude97's Avatar
Yes, the widest you should go on a 8" wheel is 245
gary c's Avatar
Nope, the 265s will work fine....265/40X18 go for it!
Old Jul 30, 2008 | 01:16 PM
redlude97's Avatar
will work fine is not the same thing as will work well. A 265 should be installed on a wheel at least 9" in width for optimal handling
Old Jul 30, 2008 | 02:06 PM
i thought stock rear were 8.5" wide?
Old Jul 30, 2008 | 02:17 PM
redlude97's Avatar
not on the 18" wheels, only the 19" wheels had 8.5" rears
Old Jul 30, 2008 | 02:20 PM
18's aren't staggered? so 8" all around? 255's then.
Old Jul 30, 2008 | 02:33 PM
redlude97's Avatar
Yes, staggered tires on nonstaggered wheels
