Tires+Wheels+drop
Old Aug 14, 2008 | 12:46 PM
Pyroalter's Avatar
Tires+Wheels+drop
I was just wondering after searching around the boards what is the best way to go with this. I really want a new set of tires and rims to start my modding off. Does it matter what order this is done in at all? Also would like a bodykit one day as well with a small drop on some 20's but was wondering what all i would need. Don't want to forget anything. As i can't look at a whole lot where I am now, i'm trying to prep for when I return home. So far with a drop from what i see i need front and rear camber kits so the tires don't wear as fast. Any help with this would be great guys and gals.
Old Aug 14, 2008 | 12:58 PM
elayman's Avatar
how much drop are you looking for? get some forged rims like volk, iforged, etc. and what kit do you want?
Old Aug 14, 2008 | 01:03 PM
Pyroalter's Avatar
can't find to much stuff on bodykits right now. Not sure how much drop either don't know much about it. I know i don't want it completely slammed to the ground but i do want some drop to it. Not sure on the measurements and whatnot. Not sure if i should focus on getting a bodykit first or tires rims and drop.
Old Aug 14, 2008 | 01:04 PM
elayman's Avatar
if i were you, i'd get rims+drop.. you can drop it a lot on coilovers, or an inch or two on springs. if you decide you only want a slight drop you could get some tein h or s techs to drop it about 1-2 inches depending on your car/which springs.. what kind of car do u have anyways?
Old Aug 14, 2008 | 01:08 PM
Pyroalter's Avatar
07 6mt dg coupe. So i'd have to go with some coilcovers with my drop? How about some camber kits and how many of each. i'm assuming 4 correct?
heres a link to a pic of it....completly stock at the moment.
http://x.infinitihelp.com/forum/pict...4&pictureid=17
Old Aug 14, 2008 | 01:17 PM
elayman's Avatar
it depends on the drop you want.. if you want to go lower than ~2 inches you need coilovers, which will probably require you get camber kit. most people just run rear camber but front is also recommended on most occasions. if you drop it w/ springs you probaby won't need camber kit unless you want to have no wear
Old Aug 14, 2008 | 01:21 PM
Pyroalter's Avatar
Thanks for all the help. Any recomendations on say a set of 20's with how much drop? I'll try to find a pic of how much of a drop. And what are some types of camberkits and coilcovers that are recommended? Sorry to be a pest. Desert won't exactly let me look at much over here.
Old Aug 14, 2008 | 01:26 PM
elayman's Avatar
idk too much about brands and such as im not dropped or have camber.. maybe some other members will help out
Old Aug 14, 2008 | 02:45 PM
nghiars's Avatar
springs will drop you from 1" to ~1.7" and if you're dropping it an inch or less, you may not even need the camber kits... you will only need 2 camber kits, a front a rear (both sets comes equipped fro left and right sides)
Old Aug 14, 2008 | 02:48 PM
nghiars's Avatar
for rims... it's really a personal decision... check out the gallery here and see what wheels you like.
Old Aug 14, 2008 | 04:19 PM
Pyroalter's Avatar
thanks for the help!
