Optional Tire Size
Old Aug 22, 2008 | 04:53 PM
1cgrimm's Avatar
Optional Tire Size
I have a 2005 G35 MT6 Sedan and I'm looking to purchase new tires. The OEM tire size is 235/45/18 but I have found that there is a much better selection of tires in the 245/45/18 size. Does anyone know if I can fit this size of tire without any issues. I looking to buy Goodyear F1 All Season tires and I don't believe they are available in the 235/45/18 size. I have had very good luck with the Goodyear tires on my BMW E36 M3.
Old Aug 22, 2008 | 04:55 PM
LuXXXz's Avatar
i think you go 255 40 18 the keep the same circumference!
Old Aug 22, 2008 | 04:59 PM
1cgrimm's Avatar
Do you know if a 255 will fit without rubbing? I don't want to roll the fenders or have any rubbing issues with the suspension.
Old Aug 22, 2008 | 05:00 PM
LuXXXz's Avatar
check it out here! put the two sizes to compare the best plus size
http://www.miata.net/garage/tirecalcold.html
Old Aug 22, 2008 | 05:40 PM
1cgrimm's Avatar
That's a very nice tool. Thanks for your help.
Old Aug 22, 2008 | 07:28 PM
kailep's Avatar
your oem's rims are 7.5" wide so 255 might be little bit of a squeeze. The '04coupe's 8" rims use 225 front and 245 rear.
Any experts want to validate that?
Old Aug 22, 2008 | 08:08 PM
G SEDAN's Avatar
just run 245/45/18 all the way around
Old Aug 22, 2008 | 09:10 PM
sloppymax's Avatar
i run 245/45/18 dunlop sportmaxx in my 06 sedan dropped on unrevised z springs. i never encountered any rubbing issues but i hardly ever have an entire car full. i have 245/40/18 Toyo T1Rs waiting to go on when these run out. i wanted to go to a shorter, lighter weight tire. if you are not lowered then i would not worry about that size even with a car full of people.
Old Aug 23, 2008 | 01:14 AM
kjo's Avatar
kjo
245/45/18 is fine.
Old Aug 23, 2008 | 02:50 AM
JustFly's Avatar
wow so according to that calculator if Im going 60mph on the speedo then in fact Im actually going 65mph with my tires. Wow I better watch out lol
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
