spacer question.
Old Sep 8, 2008 | 07:03 PM
Nismoboy's Avatar
spacer question.
What size spacers should I get if I want a crazy wide (VIP) look without having to roll my fenders? I have an 03 G Coupe dropped on Tein S.Techs. I'm already sort of stretching my tires and my wheel specs are below:
Front:
20x8.5
20mm offset
225/35/20 tires
Rear:
20x10
25mm offset
255/35/20 tires
Thanks for any input!
Old Sep 8, 2008 | 09:01 PM
Boston's Avatar
my initial response is 15mm/20mm but that's going to put you very close in the rear. I suggest you buy a set of 15mm first and test fit them on the front and rear (same side). If you think you can squeeze in a 20mm with rolling in the back buy them and if not, buy another set of 15's
Old Sep 9, 2008 | 11:06 PM
Nismoboy's Avatar
wait.. i made a mistake.. my front offset is actually +20mm not +25... so that would mean i should try a 10mm instead in the front right? or do you think 15mm is still safe in the front?
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
