how soon do i need to replace tires? front at 2 32nds, rear at 1 32nds
Old Sep 16, 2008 | 02:40 PM
chauzer's Avatar
I was at teh dealership two weeks ago for an oil change and they said rear tires are at 1 32nds and lowest recommended should be 2 32nds so they said i should replace them. The front tires are at 2 32nds.
Shoudl i replace them ASAP? and if so, shoudl i replace just the rear ones first or should i go ahead and replace all four of them now?
thanks
Old Sep 16, 2008 | 03:09 PM
idrive_MD's Avatar
i would replace them all, seems pretty low, if you're mostly in a dry area its probably ok, but I would still replace them soon.
Old Sep 16, 2008 | 03:10 PM
mIKE's Avatar
You better pray you don't hit rain.
This is my rear tire. As you can see, I'm barely touching the wear marker, and the tire is clearly worn.
Old Sep 16, 2008 | 03:12 PM
absolutg's Avatar
workin...
anything @ or below 2/32 should be replaced immediately
Old Sep 16, 2008 | 03:15 PM
ShanesG's Avatar
^+1111
Old Sep 16, 2008 | 06:10 PM
Triple8Sol's Avatar
Replace TODAY
Old Sep 16, 2008 | 08:20 PM
Don@TireOption's Avatar
Originally Posted by Triple8Sol
Replace TODAY
I agree, now would be a good time.
Old Sep 16, 2008 | 09:09 PM
BlueDevilBAMF's Avatar
Yesterday
Old Sep 16, 2008 | 09:48 PM
Seymore's Avatar
When either my fronts or backs reach 2/32 they're replaced. If the other two are anywhere close, I just replace all 4.
In your situation I'd say you're overdue.
Old Sep 17, 2008 | 02:27 AM
officerdbag's Avatar
Dude asap! I had a tire blow out on my on the highway. Very scary.
rezendvous420
May 31, 2020 01:26 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
nascarbuff17
Jul 16, 2015 10:23 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
