View Poll Results: What tires should Mike get?
Potenza 070
2.63%
Potenza 01R
7.89%
Potenza 050A Pole Position
10.53%
Ecsta MX
15.79%
Pilot Sport PS2
63.16%
Voters: 38. You may not vote on this poll
Tire choices... Mike needs tires
Old Sep 17, 2008 | 12:52 AM
mIKE's Avatar
In my research, I'm finding that T1R's generally suck. Other than lasting a long time.
It's gonna break many member's hearts...
Consumer reports and C&D both agree that they arn't great, and it's rare for those 2 publications to agree.
Old Sep 17, 2008 | 01:03 AM
mIKE's Avatar
grrr
no comparisons between the tires I'm comparing
Old Sep 17, 2008 | 03:01 AM
mIKE's Avatar
After much research, some specs:
Size
Service Description
Load Rating UTQG Max
Load Max.
Inflation
Press. Tread
Depth Tire
Weight Rim
Width
Range Meas.
Rim
Width Sect.
Width Tread
Width Overall
Diam. Revs Per Mile
Country of Origin
RE070:
215/45ZR17
Load Index 87 = 1201lbs (545kg) per tire
Speed Rating “W” = 168mph (270kph) 87W SL Treadwear: 140
Traction: A
Temperature: A140 A A
1201 lbs.
51 psi
9/32"
24 lbs. 7-8"
7"
8.3"
7.4"
24.6"
847
Country of Origin "JP" = JAPANJP
255/40ZR17
Load Index 94 = 1477lbs (670kg) per tire
Speed Rating “W” = 168mph (270kph) 94W SL Treadwear: 140
Traction: A
1477 lbs.
51 psi
9/32"
28 lbs. 8.5-10"
9"
9.8"
9.1"
25"
833
RE01R
215/45ZR17
Speed Rating “W” = 168mph (270kph) 87W SL Treadwear: 180
Traction: A
Temperature: A180 A A
1201 lbs.
51 psi
9/32"
24 lbs. 7-8"
7"
8.4"
8"
24.6"
848
255/40ZR17
Speed Rating “W” = 168mph (270kph) 94W SL Treadwear: 180
Traction: A
1477 lbs.
51 psi
10/32"
28 lbs. 8.5-10"
9"
10.3"
9.4"
25"
834
I guess weight is no longer an issue, but the 070 has a *smaller* contact patch on the front? Looks a bit suspect... I guess I'll go to a honda dealer and do some measuring...
wtf.
Old Sep 17, 2008 | 04:38 AM
driftGT350's Avatar
< / 3
haha. I wish I could afford stickier tires. good luck yo!
Old Sep 17, 2008 | 06:58 PM
mIKE's Avatar
sticky tires are ftw.
Old Sep 17, 2008 | 07:55 PM
ttrank's Avatar
Grocery getter
Once my car is not a DD, I'm going to downsize to 19's and get something like that.
Old Sep 18, 2008 | 04:06 PM
officerdbag's Avatar
Dude... PS2's FTW
Old Sep 18, 2008 | 04:44 PM
chicklet's Avatar
Yeah I don't think I will ever own another tire for my car...PS2's are the best all around.
I have them on my M with Z wheels and they are perrrfect!
Old Sep 18, 2008 | 08:30 PM
mIKE's Avatar
The PS2's are the second least stickiest tire of the ones the list....
Old Sep 19, 2008 | 04:44 PM
SIN3's Avatar
get all 4!
Old Sep 20, 2008 | 05:01 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
i dont get it.. you pretty much only have 2 tires to choose from... the 070's or the 01R's... pick one already!!! Either way they're both a great tire so you cant go wrong.
-GP-
Old Sep 20, 2008 | 05:04 PM
chenG35's Avatar
http://www.tirerack.com/tires/tests/...lay.jsp?ttid=1
Tire Rack is showing the RE050A PP to outperform the Goodyear Eagle GS-D3 in virtually every performance category.
The RE050A PP is a very recent design... only 2 years old.
Thank you for the suggestion, but I think I will pass on the GS-D3 if it performs at under RE050APP levels.
Any other tires that I should look into?
Thanks for the feedback guys.
Where does it show GS-D3 to perform under RE050A PP? Maybe I'm biased, I love my set of GS-D3s and they grip like glue. I ran them for 20K now (non-grandma driving) and still got like 40% tread left. The only thing is they began to get louder wayy before they're fully worn, so I might change them early even though I have at least 5/32 left. Already got a set of PS2s ready
Old Sep 20, 2008 | 05:10 PM
mIKE's Avatar
If you've ran the tires for 20k, then I don't think they're quite as stick as you think they are.
Try a set of RE01R on your car
I have 15k on my 070s, and theyre BALD (1.25/32" left)
Most guys that run this tire go betwen 3-8k. Had I been driving 100%, I'd be right there with them... I've been trying to conserve tire life as much as possible when not involved in HPD.
At this point I'm pretty much leaning toward another set of 070, as I havn't really seen any convincing arguments towards another tire...
Old Oct 6, 2008 | 01:16 AM
dbarnes's Avatar
Sorry, Mike - But look again, Pal .
The Goodyear Eagle F1 GSD-3 kicks ***, and the "test" from Tire Rack you were referring to was done in 2005, while their latest comparison done 10/26/2007 shows the GSD-3's clearly superior in every aspect to the PS2's, The PP's, etc. etc. - just like Road & Track found out, too.
Check it out ..
http://www.tirerack.com/tires/tests/...y.jsp?ttid=101
Been running the GSD-3's now for the past two sets, mostly around the suburbs and freeway driving, with as many hard runs down canyon and back country roads as I get the chance. I get just about 19K -20K miles per set on my '04 6MT Sedan, and the right rear is nearly bald now at 20K (new set ordered from Tire Rack today, 235/50/17). 66,000 miles on the car now, 3rd set of tires toast (the stock tires with '04 sport suspension were also Goodyear Eagles, but not GSD-3's, and they went about 26K).
These GSD-3's stick, especially, (even scary) well in the rain - I think better than on dry ground. And they don't fade during hard mountain runs up Hwy 88 to Lake Tahoe from the Bay Area (SF, California). Taking a hard corner, or even freeway ramp sweeper, in a driving rain at high speed is absolutely jaw dropping....
These tires mean business, and at a reasonable price for the performance, but like any sticky tread, don't count on more than 17K-18K miles till they're worn out, and much less if driven very hard very often. Don't pass them up without serious research - or they'll pass you up on Hwy 88...LOL...
'Nuff Said.
DB
Old Oct 6, 2008 | 01:44 AM
  #30
Skaterbasist's Avatar
Retired SuperMod
The Goodyear Eagle F1 GSD-3 have a very soft sidewall.
I'd go with the PS2's. They are great in every type of environment, even though they might not be the stickiest ou there.
