Anyone w/ lowered G using Rhino Ramps?
Old May 17, 2004 | 06:43 PM
NicNoobie's Avatar
I just picked up some plastic Rhino Ramps to install my sway bars, but I couldn't get the front end of my G up the ramp. It's too low, and just pushes the ramp away. I tried placing some 2x4's before the ramp, but that didn't help. I wound up using my floor jack & stands, which is another pain since I have to drive my car onto the 2x4's for jack clearance.
I kinda want to be able to use the ramps for oil changes and such. I'm sure some of you have faced the same problem. I'm just wondering what solutions you've come up w/ to resolve the issue. Do they sell extensions for the plastic Rhino Ramps?
Many thanks,
- NICNoobie
2003.0 AT Brilliant Silver Sedan
Premium\Graphite\Clear Corners\AEM Intake (w/BV)\Eibach Pro Kit\Eibach Sways
"Why are you my English not being understanding?"
Old May 17, 2004 | 08:03 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: Anyone w/ lowered G using Rhino Ramps?
I've heard a G with stock suspension has problems with the Rhino ramps. You might want to try the metal ones with the extensions.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Old May 17, 2004 | 08:09 PM
redwillow's Avatar
20 Year Member
i got yellow metal ones at wal mart & ordered the extension kit for them. No rubbing.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, double 15% tint
Old May 17, 2004 | 09:51 PM
bkchang79's Avatar
Even the ramps with extension from Griot's garage, I still can't get my G on those things.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
http://www.sounddomain.com/id/bkchang79
Old May 18, 2004 | 02:57 AM
G35SanDiego's Avatar
Yeah those ramps are usually to steep for most cars. I was talking to the guy at autozone a while back and he told me that even some minivans can't clear them. I once considered welding up some of my own. But after drawing out the measurements I realized that they would be so long that weight would and storage would be to much. I am now looking for a super low profile hydraulic jack for my cars.
Old May 18, 2004 | 05:39 AM
skeleton_cru's Avatar
Sedan
The Rhino ramps will work with the stock suspension and stock bumper.
Old May 18, 2004 | 08:22 AM
DHCrocks's Avatar
I got some plastic ones from checkers and they work fine on a stock height coupe, but I can see that they might not cut it on a lowered one since they barely clear the bumper. I can't even get my floor jack under the front at stock height. I learned a trick from a friend, use the stock jack to lift a front corner just enough to slide the floor jack under and you're good to go. When lowering the car since the suspension was unloaded, it will sit a little higher off the ground so you can simply drop the floor jack and it has enough room to slide out.
Old May 18, 2004 | 10:22 AM
CookG35's Avatar
The Rhino's work with my lowered sedan/Nismo bumper but only if I stack 2 pieces of MDF/particle board (3/4" thick) in front each ramp. Not the best method....but it works.
Old May 18, 2004 | 11:10 AM
GR8TG35's Avatar
If your looking for a low profile floor jack check here they seem descent and not a bad price.......hope this helps....
Also, I know Sears has a low profile aluminum floor jack rated at 4,000 lbs, but its priced at $199
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
