INSTALLING NEW WHEELS...TIRE PRESSURE SENSORS?
Old May 17, 2004 | 07:25 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Hi,
Can I install AF wheels and still keep my tire pressure sensors?
2 G or NOT 2 G, there is no question!
Injen SES, Kinetix cats, K&N Typhoon, 19" PIAA Super Rozza's (19x9 & 19x10)
Old May 17, 2004 | 08:20 PM
THX723's Avatar
G Kreuzer
Re: INSTALLING NEW WHEELS...TIRE PRESSURE SENSORS?
Randy,
As long as the sensor is able to sit reasonably flat against the surface then it's ok. Otherwise the in-board centrifugal switch will never trigger to turn on the unit as the wheels spin.
Also be sure to follow the correct procedure outline in the service manual while mounting or dismounting the tire. The sensor is easily damaged, especially durring the tire mounting process. They busted one of mine in half
Clint (THX723)
Old May 19, 2004 | 03:19 PM
Gojira's Avatar
Clint,
Where can I get a copy of the Service Manual that outlines this procedure?
I'm considering putting the OEM sensors on aftermarket rims, too.
Thanks
Old May 19, 2004 | 03:49 PM
Gojira's Avatar
Can you post a copy in this thread?
Thanks!
Old May 19, 2004 | 11:38 PM
THX723's Avatar
G Kreuzer
Here you go.
Page 1
Clint (THX723)
Old May 19, 2004 | 11:40 PM
THX723's Avatar
G Kreuzer
... give me a break! ... over by 7 bytes! Poop!
Page1 ... take 2.
Clint (THX723)
Old May 19, 2004 | 11:41 PM
THX723's Avatar
G Kreuzer
Page2
Clint (THX723)
Old May 20, 2004 | 12:20 AM
R2 V35's Avatar
Clint,
Did you install the sensors on your ride?
6MT Ivory/Willow>>Nismo OEM Kit>>Premium Package>>XM
"Is simplicity best or simply the easiest"
Old May 20, 2004 | 12:31 AM
THX723's Avatar
G Kreuzer
Well ... I've tried. After they broke one in half durring the first attempt, I kindly ask them not to do it again. This is, of course, before I found out what the proper mounting procedures were. Darn it ... I knew I should of checked first!
I'm still looking for a way to replace or fix the busted one. I'd love to get them installed in my new wheels.
Clint (THX723)
Old May 20, 2004 | 02:46 AM
a.k.a. RANDYS_G
Clint, the weirdest thing happened. I had my AF wheels put on and did not remove the sensors from the stockers and tonight on the way back from LACR, the sensor gauge came on...anyway to disable it?
Old May 20, 2004 | 03:19 AM
THX723's Avatar
G Kreuzer
Unfortunately no. It's normal that it goes off while the system checks with the sensors that are no longer there. It's not a big deal really.
Clint (THX723)
Old May 21, 2004 | 04:50 PM
Gojira's Avatar
Clint,
Thanks for posting the sensor installation info. By the way, do you need to do this any time the tire is removed? In other words, just for changing tires on the OEM wheels for example?
Thanks!
Gojira
Old May 21, 2004 | 05:40 PM
THX723's Avatar
G Kreuzer
Yup. Every single time ... a real pain in the ****!
Clint (THX723)
Old May 25, 2004 | 12:48 AM
bigwilly's Avatar
Is it possible to get another set of sensors from the dealer for the aftermarket wheels? Also any idea if the 2004 G35X sedans have the tire pressure sensors standard. I think I read that it was standard but not 100%. I eventually want to get aftermarket rims and tires.
Old May 25, 2004 | 03:00 AM
THX723's Avatar
G Kreuzer
You can certainly get a new set of sensors for your aftermarket wheels, but your car will not recognize them unless you reprogram the system to do so and will at the same time render the old set of sensors useless.
All 2004s do indeed come standard with tire pressure sensors.
Clint (THX723)
jsimonk
Dec 22, 2023 03:49 PM
mtlruss
Dec 20, 2015 01:51 PM
RA102223
Aug 15, 2015 09:24 PM
joedaddy1
Jul 28, 2015 02:58 PM
