Tire Pressure Monitor???
Old May 18, 2004 | 07:32 PM
Vic's Avatar
Vic
I'm going to put 20" rims on my coupe. What will happen to the tire pressure monitor? will it still work if I swap the 18" stock rims with 20" rims?
Thanks.
TB/Black, 6MT coupe, Aero, Premium, Navi, Pop Charger + Z-Tube, Clear Corners, 30% tint.
Old May 18, 2004 | 08:06 PM
GRider35c's Avatar
Re: Tire Pressure Monitor???
you need to take the monitor from the 18's and put them on the 20's, have infiniti dealer do it, or it will break or void the warranty
2004/BO/G/aero/splash/prem/perf/cc/22%tint
Old May 18, 2004 | 10:45 PM
metasystem's Avatar
04 G35 Coupe 6MT Gold Brembo’s
Vic,
Grider35 is right...
The low tire pressure warning system monitors a signal sent from sensors installed in each wheel. The system won't function if you replacing the wheels or mount the spare.
Get the dealer to replace the tires and they will install the sensors and reset the system.
2004 G35C 6MT + Nav, Silverstone
Old May 18, 2004 | 11:42 PM
Vic's Avatar
Vic
the tires have already been mounted on the 20's.. I think I'll just leave the way it is.. Is it a good idea not to have the tire pressure monitor working properly?
Old May 19, 2004 | 05:38 AM
metasystem's Avatar
They're nice to have but if you check them periodically with a good gauge then you don't need them. The 03 coupes don't have them. Without them, swapping rims seasonally is much less of a headache -- you can do it yourself if you want.
Old May 19, 2004 | 10:33 AM
glennp_1999's Avatar
The tire pressure monitor works with all four if one is out then it won't function. No biggie really just check your tires occasionally to insure proper inflation.
<font color=blue>04 CB COUPE / WILLOW / PREM PACK</font color=blue>
Old May 19, 2004 | 12:34 PM
Vic's Avatar
Vic
thanks guys for the reply. If the tire pressure monitor is not functioning, will the tire pressure sign keep blinking all the time?
Old May 19, 2004 | 02:00 PM
Cruz's Avatar
No, the TPS warning light wiill come on after you put the new wheels on but it will go away after you turn the car off/on again.
XMLM
Old May 19, 2004 | 02:36 PM
Vic's Avatar
Vic
I see.. well it's no biggie then.. I used to owned a car with no TPS and it's not a problem at all.
Thanks again for the help guys.
Old May 19, 2004 | 03:07 PM
Catatafish's Avatar
I used to have a car with no air condition, no power steering, and no power brakes too.
My point is, you're driving one of the finest automobiles on the road! Don't make compromises, have the monitors installed back in. It's a great feature and it may save your wheels some day. You can't check the air pressure driving around while your wheel is losing air.
2004.5 Coupe/5AT/Ivory/Everything but chin spoiler/Z Tube-Popcharger/Crawford V5 Plenum on the way
Old May 19, 2004 | 09:26 PM
dave's Avatar
Just a minor thing... If you drive the car for about 30 minutes, the TPS light will come on. It goes back off when you turn the car off and back on.
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Danielek
Sep 20, 2015 12:08 PM
JoeMac
Aug 20, 2015 10:17 AM
