Rim dont fit with stock BRAKE ROTORS!!???!!!
Old Oct 6, 2008 | 10:24 AM
Engineerseller1's Avatar
I just bought new rims basically same sizes as my stock for the 2004 g35 coupe... Now my problem is my STOCK brake rotors have a stud looking thing.... i think its so i can align the rotors.... But do to this stud my rims will not go on nor sit flush to the rotor..... Should i grind them off.... b/c i dont have the time or money to buy new rotors right now and mine are almost new to begin with..... PLEASE HELP ME OUT THANKS!
Old Oct 6, 2008 | 12:57 PM
codeflux's Avatar
the stud is to make sure you don't mix up front and rear wheels - front wheels on 04 coupe are 18x8 and rears are 18x8.5 (or is it 18x7.5 and 18x8?). make sure you have the correct tires on the correct wheels! - the stud is what's preventing you from making that mistake. btw, your tires are staggered too - 225 front and 245 rear, if i'm not mistaken.
Old Oct 6, 2008 | 02:40 PM
EL-EE-ES's Avatar
+1, just pull the stud off, you dont need it
Old Oct 6, 2008 | 02:48 PM
Hi-TechG35's Avatar
Use a 12mm and unscrew the bolt. It is just there to assist when removing the caliper.
Old Oct 6, 2008 | 05:49 PM
codeflux's Avatar
remove it or not, please make sure you put the correct wheels and tires on the correct end of your car.
Old Oct 6, 2008 | 05:51 PM
eljoker's Avatar
There was a DIY or somthing about it its there so you dont rotate the wheels between front and back just cut it off.
Old Oct 7, 2008 | 03:54 PM
G35fromPA's Avatar
You are correct that the stud is to prevent mixing front and rear (and is easilyremoved), but all four wheels on the 04 coupe are 18x8. It's only the tires that are staggered.
Old Oct 9, 2008 | 07:55 AM
Thanks So Much!!!
Yea i found out basically it is crap.... Its just a bolt with a metal sleeve and are only on the front 2 tires.... I called my infiniti dealership asked service and parts and they dont have a clue what the hell it was for!!! LOL
Thanks guys got my rims put on yesterday look sick!!!
Old Oct 9, 2008 | 08:51 AM
GreenGoblin's Avatar
The goblin resurrection
so where are the pics of the new shoes
Terry_G35
May 9, 2020 01:39 AM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Terry_G35
Aug 4, 2015 02:38 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
RedBaronK
Jul 27, 2015 03:19 PM
