Anyone Try These Camber Arms?
Old May 26, 2004 | 12:23 PM
khsonic03's Avatar
http://iapdirect.com/item.asp?invid=622
Just curious. I can't get a hold of Kinetix, and I need a set pretty badly. They come with adjustable toe cam bolts.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, 19" Gram Light 57F Pro's, Hotchkis sways, Borla
Old May 26, 2004 | 05:33 PM
Gsedan35's Avatar
Re: Anyone Try These Camber Arms?
Thats a better price for the kit then I've been able to find. That's the correct way to adjust for toe, not with the radius arms they try to pass off as toe control arms. Factory does not adjust toe that way for a reason. If you need to adjust toe and the oem adjustment isn't enough, that is the kit to do it with.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old May 26, 2004 | 05:47 PM
al503's Avatar
Looks like I'll be able to save a couple hundred bucks and get 'better' adjustability.
Jim, is there any reason to get the other maker's toe and camber arms instead of these?
Old May 26, 2004 | 05:56 PM
protocav's Avatar
the toe cams arrived at my house today, and i already have the kinetix camber arms. i plan to get it aligned tomorrow, wo i will post with my experience. i talked to the manufacturer about the cams, and he said that they are good for an additional .5 degree of toe. i don't know how that will translate to camber, however.
Old May 26, 2004 | 07:31 PM
al503's Avatar
It looks like the price on the site is for each arm so the cost will be somewhat similar to the jic and stillen arms but you still get the toe adjustability.
proto, sounds like you were able to get the toe cam separately. Could you please tell us how much? I might do the same thing as you and go with the kinetix camber rod with the SPC toe cam.
Old May 26, 2004 | 09:14 PM
khsonic03's Avatar
I don't know, that seems odd that they would sell it as each side. It says that it is a "kit," so I would hope that would mean both sides. If not, that stinks because I won't pay over $400 for camber arms. I called the manufacturer today, and found out some things (except for the pricing). The arms are very new and they are MIG welded instead of TIG welded. They also use rubber bushings very similar, if not identical to the sotck ones vs. polyurethane like the Kinetix arms. I am going to buy these if $220 is the price for both sides. I can't wait any longer for Kinetix to answer all of my phone calls, emails, and PM's. It's just ridiculous for a customer to beg the manufacturer to call him back just so he can place an order. I'll let you all know my findings. They seems to be good quality, and the company is pretty large.
Old May 26, 2004 | 09:38 PM
khsonic03's Avatar
No, you were right. I just checked their homepage. It says one kit required for each wheel. I guess I won't get them.
Old May 27, 2004 | 01:01 AM
Gsedan35's Avatar
How much were the toe cam bolts by themselves?
Edmund Burke
G35 6mt
Old May 27, 2004 | 01:23 AM
protocav's Avatar
the toe cams were 45 bucks total.
Old May 27, 2004 | 11:40 AM
al503's Avatar
Hey proto,
Let us know how the alignment goes. Is there any reason those to cams might not work the kinetix? If not, it looks like the kinetix camber arms and the toe cams for ~$265 may be the way to go.
Old May 27, 2004 | 11:55 AM
khsonic03's Avatar
Yeah, if you could ever get in touch with Kinetix. This is ridiculous. Anyone know of a good way to order some arms? If he can't respond to my phone calls, emails, or PM's, I am not sure I want to order the things on the internet. Who knows if I will ever get them or if it will be too late.
Old May 27, 2004 | 03:59 PM
GPhanatic's Avatar
Hey Guys, I contacted IAP and they said the price of $219 is for both left and right together camber arms!! Woohoo
Old May 27, 2004 | 10:00 PM
SuperCharged6MT's Avatar
so do you need 2 sets or 1 to fully align the whole car?
Thanks....
Old May 27, 2004 | 10:12 PM
khsonic03's Avatar
Well, now I really don't know what to do. Kinetix FINALLY responded and said he would ship them out tomorrow if I wanted. Which ones should I go with???? Kinetix or the SPC with the toe cams??? Oh crap. I like the polyurethane and the TIG welds on the Kinetix, but I like the toe cams included with the $220 plus the rubber bushings would be quieter for the car (although I probably wouldn't notice).
Old May 27, 2004 | 10:20 PM
khsonic03's Avatar
I think I am going to go with the Kinetix. They are tried and true, plus I like the polyurethane over the rubber, because there will be less camber change during hard cornering due to deflection of the bushing. I still welcome opinions, but I will be ordering tomorrow (fri).
