Infiniti Service Interpretation
Old Nov 7, 2008 | 03:30 PM
tlo57's Avatar
Hi, I just got my an oil change at the dealership the other day and with about 14,000 miles on my G35c - I just wanted to know what the multi-point inspection meant.
FRT TIRES @ 6 32NDS. REAR @ 5 32NDS, FRT PADS ARE GREEN, REAR ARE 6.5MM
I was wondering does this mean I have to replace my brakes/tires soon? When will I have to replace them? I'm just not sure what the measurement of 32nds is? I tried googling it but I came up with nothing, I know this is kind of a newbie post but any help would be greatly appreciating.
Old Nov 7, 2008 | 03:50 PM
athens's Avatar
Disc brake pads are considered worn when less than 2.0 mm. So at 6.5 mm you have enough brake pad life left.
Tires have tread life based defect warranties to 2/32" (i.e. the fraction of an inch with the inch divided into 32 segments). Most tires start with 11/32". 2/32" is at the tire tread wear bars. However traction and ride quality may be less than optimal in less than 5/32" tread depth. So you might want to start looking for new tires.
Old Nov 7, 2008 | 06:05 PM
mIKE's Avatar
Front pads are fresh, rear pads are at about 1/2 life left.
Front tires are about 1/2 worn, rears are a bit over 1/2 wor.
New tires are 10 or 11 32nds. At 4/32", you have compromised wet weather handling
at 2/32", the tire is no longer safe to drive on at all.
neight
Accessories
Jun 29, 2020 12:24 AM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
snic09
Nov 8, 2017 01:46 PM
sinasajadi
Aug 26, 2015 04:12 AM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
