Okay, I know the lugs will be torqued to 80lb on the 'new' wheel studs, but what about the spacer itself? 80lb as well? Use antiseize on the spacer lugs, too? Thanks!
Okay, looks like it should be the same as the wheels and antiseize, probably not a good idea except for on the hub.
