OE 19s and Z S-techs and 20/25mm spacers
Old Dec 15, 2008 | 12:53 PM
Dan_G's Avatar
well, i have an 05 sport, the spring rates are very close(higher in the front though). from the suspension sticky:
Oem linear springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2006
Front:314 Rear:427
Any spring or coil over that has “stiffer then oem springs by” does not factor in the higher rear spring rates of 2005 coupes with oem 19’s or 04.5+ oem 350Z’s
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
I will take some pics Wednesay after my allignment (hopefully they will have settled already)
Old Dec 15, 2008 | 11:03 PM
Matthew121's Avatar
did you preload the suspension (or do you even have to?)
I know when I installed springs on my rx8, you had to preload the springs to get it to settle correctly, I used a jack and raised the rotating asembly up while the A bar was loose after the spring was fully compressed and the car started to life up you tighten that A bar, and thats it. or you leave the 2 bolts for the bar loose drive it around the block, turn the wheel and tighten them.
I didnt have to do this for any of my other cars though.
and I have a 04 sport, but I kinda want a stiffer spring. I am think about the z swift springs now that I hear the z stechs arnt much of a improvement.
Old Dec 16, 2008 | 10:07 AM
Dan_G's Avatar
Oem linear springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004
Front:314 Rear:342
Swift 350Z linear springs .8”/.6” drop on 350Z, G35 drop will be higher)
Spring rates in LBS 336/364
S-techs would be stiffer for your car
Old Dec 16, 2008 | 10:10 AM
MTG35guy's Avatar
Looks good bro. Spacers put the wheels out there just enough. Nice drop too.
Old Dec 16, 2008 | 04:32 PM
Matthew121's Avatar
Originally Posted by Dan_G
Oem linear springs
350Z’s 2003/2004
Front:314 Rear:342
oh I see, thanks man,
where are you getting this info?
Old Dec 16, 2008 | 05:19 PM
Dan_G's Avatar
no worries, 3rd sticky of the suspension/brakes subforum... lots of info on there
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
