Thinking of running 245-35-19 on all 4 coupe wheels for my sedan
Old Jan 10, 2009 | 05:21 PM
  #46
Jeff92se's Avatar
Red Card Crew
Pilot sport max summer tire. Would have been nicer to have the PS2s but can't be too choosey.
http://www.tirerack.com/tires/tires....el=Pilot+Sport.
I was also looking at the RE050s in 245-35-19 all around (nice tire but 140 UTOG) or the Dunlop direzza 101s in the same size (but their wet performance was horrible). I can't have **** wet performance up here.
Old Jan 10, 2009 | 05:31 PM
  #47
G SEDAN's Avatar
how dare you not support your fellow japanese by buying some yokohamas!
jk jk
Old Jan 11, 2009 | 03:09 AM
  #48
Rodrigo's Avatar
lol ^ im running the yokohama S drive and they are awsome, took 500 miles or so to brake them in , they replaced the oem re050.
for the 255 40 19 you WILL need to roll the fenders in the rear.
Old Jan 11, 2009 | 01:53 PM
  #49
Jeff92se's Avatar
Red Card Crew
The rears I got are 255-35-19. Tad smaller than oem diameter. Which is where I wanted to error.
Old Jan 12, 2009 | 11:15 AM
  #50
blklude98's Avatar
I also went with 225/40/19 and 255/35/19 with my G coupes. Ride is still good and it keeps it pretty damn close to spec. No rubbing issues either with my Z front springs and G coupe rear suspension.
Old Jan 12, 2009 | 11:39 AM
  #51
Jeff92se's Avatar
Red Card Crew
Awesome. That's the 2nd person to mention no rubbing issues w/ the 255-35 combo. Other guy was running Kumhos in that size.
Who thinks we should have a tire test sticky in our little section? I could post a 2005 R&T tire test and I found a tire test from Europe that looks at the Verdenstien tires (rated #1 on that test).
Old Jan 12, 2009 | 01:38 PM
  #52
Tollboothwilley's Avatar
i have 245/35/19's all around
I'm running the re050a Pole positions, not to be confused with the re050a
perfet setup, rotatable
  #53
5% is the allowable difference in diameter for the VDC
Old Jan 13, 2009 | 01:15 PM
  #54
blklude98's Avatar
Def...us maxima guys gotta back each other up!
Pic for reference... Z front springs, G coupe shocks/springs
225/40/18F / 255/35/19R BOTH TIRES are TOYO Proxes T1-R
Old Mar 10, 2009 | 02:45 AM
  #55
Jeff92se's Avatar
Red Card Crew
Finally got them mounted. And just because I'm a weight *****:
oem RE050s:
225-40-19 = 25 lbs.
245-40-19 = 30 lbs.
Michelin Pilot Sports:
225-40-19 = 21 lbs.
255-35-19 = 24 lbs.
I saved 4 lbs off the fronts. 19s & tires = 43 lbs. vs 47 lbs.
I saved 6 lbs of the rears. 19s & tires = 47 lbs. vs 53 lbs.
All weights are probably +/- 1 lb or so.
Not bad for a 220 utog vs 140 and a better tire review.
For reference, my oem 17 wheel and blizzak 215-55-17 came in at 45lbs each. I'm lighter them oem in front and just a tad heavier in the rear. Not bad for going +2 and 10mm / 40mm wider!
Old Mar 10, 2009 | 10:17 AM
  #56
coup de grace's Avatar
I just got coupe 19s installed on my X, running 245/35/19 Toyo Proxy 4s all around.
Old Mar 10, 2009 | 10:33 AM
  #57
ihaveamustang's Avatar
oem RE050s:
225-40-19 = 25 lbs.
245-40-19 = 30 lbs.
225-40-19 = 21 lbs.
255-35-19 = 24 lbs.
I saved 6 lbs of the rears. 10x & tires = 47 lbs. vs 53 lbs.
Pics? Interested to see that front gap. I think the 245/35 front setups that I've seen look a little thin w/ the z springs. I'll have the same z/cpe setup when I can track down some wheels.
Old Mar 10, 2009 | 12:04 PM
  #58
Jeff92se's Avatar
Red Card Crew
Here's a pic with the oem 225-40 and 245-40 19s on. Coupe rear/Z front springs.
I'll post pics of the new setup when I actually mount these on the G. Still a slight threat of snow here.
The rear 255s aren't nearly as wide as I would have thought. And the 225 fronts seem narrower then the bridgestones.
Old Mar 10, 2009 | 12:40 PM
  #59
Klubbheads's Avatar
oem RE050s:
225-40-19 = 25 lbs.
245-40-19 = 30 lbs.
225-40-19 = 21 lbs.
255-35-19 = 24 lbs.
Those are some major savings. I wonder how much weight i will save if i swap my RE050 runflats with T1Rs or your tires.
Old Mar 10, 2009 | 12:57 PM
  #60
apintojr's Avatar
Originally Posted by G SEDAN
why not run 245-40-19 all around? tire too expensive?
thats what i run, but then again i have an X.
