Tires deflating??
Old Jan 6, 2009 | 04:29 PM
RAF702's Avatar
Tires deflating??
Wierd situation going on. For the first time since I've own the car, The TPM light turned on. So of course went to check it and the passenger rear tire was low. Added air to reach appropriate tire pressure, then within the next 2.5 weeks. Seems like every 3 or 4 days the TPM would go on and yes the tire is low again. I hear or see no visual holes or any object protruding from the tire. So I filled up air again.
And yesterday The TPM light turns on once again, so I figured somethings wrong with the tire. So I go check it and the tire is holding pressure. Got me confused, so I check the other 3 tires, and see that the rest were all low. Those times I was putting air in the rear tire, I would still check the tire pressure in all the other tires incase and they were good. So I'm stumped, all the tires have around %85-90 tire tread.
What do you guys think?
Old Jan 6, 2009 | 04:49 PM
kennyb's Avatar
Where do you live? Sometimes when your car sets overnight in colds temps your tires loose pressure. Just a little like 1 to 2 lbs. But if you don't live in the Northern States with freezing temps, don't worry about this issue.
Old Jan 6, 2009 | 04:59 PM
kenchan's Avatar
check to see if your valve stem core is loose or not.
if loose, tighten it gently.
Old Jan 6, 2009 | 05:05 PM
Seymore's Avatar
Sounds like decreased pressure from an increase in cold temps? I've had to add air twice so far this winter to kill the TPMS light.
Old Jan 6, 2009 | 05:20 PM
kenchan's Avatar
it's possible. with 10F ambient temp change that'll change 1psi.
Old Jan 6, 2009 | 07:31 PM
RAF702's Avatar
I live around the Pasadena (626) area, but everywhere I drive the outside temp's have been around ~45-57 degrees lately Mornings and evenings. I can definitely understand the cold temps affecting the tire pressure.
How would I know if the valve stem core could be the culprit? Would air be leaking from there or something? According to the the door panel, correct tire pressure indicates 35psi for all 4 tires. I would seriously see it jump from 35psi to around ~22-25 in just a few days. Till I refill it back with air.
Old Jan 6, 2009 | 09:07 PM
kenchan's Avatar
it could be a very slow leak so you may not hear it leaking from the valve core.
they sell these little tools to turn the core at most autoparts stores. if you have a
thin long nose plier you can slide the two tops into the valve stem and turn it gently
clockwise.
the top tip is wat you would use.
Old Jan 6, 2009 | 10:53 PM
RAF702's Avatar
Thanks!, I'll go check that out
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
