OEM 19 Tire Size Combos
I have OEM Potenzas. Fronts are worn to hell, bad cupping. Rears are fine have only 6-7K miles on them.
Want to move to different tires (Yokohama S.Drive,Hankook Ventus v12 evo, etc... ) in the ~$200 range.
Can I move the Potenza 245/40/19s from the back to the front and start the transition by putting 255/40/19 Yokohama etc.. on the rear?
If not can I put 235/35/19 Yokohama in the front (to maintain the stagger) and when the rear Potenzas die put 255/40/19 yoko in the back?
Thanks
Thanks
As long as you match the rear accordingly, no.
marsman328
Northern California
Aug 11, 2015 07:29 PM
