Wheel fitment problem
Old Mar 9, 2009 | 08:40 PM
BlkThoe's Avatar
04 G35 6MT w/brembos. 20x9 Axis Shine wheels +15 offset. 245/35R20 H&R 1 inch drop. My problem is a tire rubbing issue. I have called Axis and apparently mine is the only G35 that has ever had an issue with this. As it is, the car is sitting with -2.1 degrees camber, and I can't put my camber kits in with this problem or my fenders will be destroyed. The only other option I have thought of is to elongate the lower control arm mounting hole and make a camber adjustment from the lower control arm, pulling the bottom of the tire inward rather than pushing the top out. Any ideas or help would be greatly appreciated. I can put up some pictures later.
Old Mar 9, 2009 | 08:45 PM
redlude97's Avatar
its rubbing in the front or the rear?
Old Mar 9, 2009 | 08:52 PM
BlkThoe's Avatar
Front, rears are 20x10 with 285/30R20 with no problems.
Old Mar 9, 2009 | 08:54 PM
redlude97's Avatar
run the CORRECT tire size, 245/30/20 and you should have no problems. Your current tire is almost an inch taller than stock, which is causing your clearance issues
Old Mar 9, 2009 | 09:25 PM
Thinkdiesel's Avatar
yea im curious why are there so many 245/35 out there? cheaper? and why do the tire places pushes to use it? confused...
Old Mar 9, 2009 | 09:33 PM
redlude97's Avatar
i have no idea either...anyone that can use a tire calculator should be able to see that it is a horrible choice to use though
Old Mar 10, 2009 | 12:23 AM
BlkThoe's Avatar
Yes, that would help, but still wouldn't solve my problem. The 245/30 would be the same width as the 245/35 and my issue is the wheel being too far out as it is. I would still have the problem, just not as severe.
Old Mar 10, 2009 | 03:20 AM
redlude97's Avatar
no, the suspension cambers inward as it moves through the its travel, so it should not rub. 20x9+15 is NOT aggressive
Old Mar 10, 2009 | 11:22 AM
BlkThoe's Avatar
I'm aware that the wheel cambers in as it moves upward. As it is, with -2.1 degrees it rubs. Once I put my camber kits on it will be BAD.
MsFitFern
Aug 9, 2015 02:58 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
sailfish250
Jul 30, 2015 11:39 AM
Soumilg
Jul 18, 2015 12:33 PM
